Old 04-09-2012, 08:44 PM   #1
allaboutchevelles
allaboutchevelles's Avatar
01 silverado 1500 rear calipers sticking
I just replaced my rear brake pads today and now both the calipers seem to be sticking a little. When I drive the truck around the block and get back home the wheels are real hot and you can smell the pads burning. but when I back up on a hill and put it in nuetral it will roll down the hill so they dont seem to be sticking real bad. I even put wd-40 under the piston boot and worked the piston in and out a few time, didnt help. This seems to be a problem on these trucks. I guess I need to replace both calipers???? anyone have and suggestions??
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline   Reply With Quote
Old 04-09-2012, 10:32 PM   #2
clinebarger
Re: 01 silverado 1500 rear calipers sticking
New pads will make a smell when "seating-in". Did you grease the caliper slide pins?
Rust can build up between the brake hardware/pad anti-rattle clips & caliper bracket Causing the pads to stick.
clinebarger is offline   Reply With Quote
Old 04-10-2012, 06:05 PM   #3
truckdude239
truckdude239's Avatar
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 04-18-2012, 10:26 PM   #4
allaboutchevelles
I put a new set of calipers on from napa for 100 bucks for the set. No more problems, perfect now.
Old 04-19-2012, 09:35 AM   #5
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Glad ya got her fixed!
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 04-19-2012, 10:39 AM   #6
bwood
bwood's Avatar
I had a very similar issue with my Mom-n-laws 99 S10 Blazer. Calipers stuck all the time, turned the rotors blue. I pulled a caliper and when I forced the piston back in with a c-clamp, rusty nasty brake fluid came out. I also replaced the calipers, lines, pads and rotors. I also just kept let the rear lines run fluid out constantly while keeping the MC full until I got clean fluid out. She doesn't drive it much and I assume moisture built up in the rears due to a damaged seal or something.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Thread Tools
Display Modes
