Old 04-10-2012, 10:18 PM   #1
squirrely_1
trailer lights
i have an 05 silverado, i have 2 boat trailers which i have made sure everything on the trailers as far as lights go is working. As soon as i hook my truck up and hit the brake pedal, all the lights go out? any ideas? also when the turn signal is on, the lights go out when the turn signal is on on my truck and come immediately back on as soon as it goes off on my truck?
squirrely_1 is offline   Reply With Quote
Old 04-11-2012, 09:17 AM   #2
truckdude239
truckdude239's Avatar
Re: trailer lights
do the lights go out on the truck or the tailer i probley say you have a bad ground on the tailer light harness
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 04-11-2012, 12:00 PM   #3
squirrely_1
Re: trailer lights
the lights on the truck work fine while connected, but when the brake lights on the truck are illuminated, the trailer lights go out, like power gets cut off to the whole harness, as soon as i release the break pedal the trailer lights come right back on! Same whith the turn signals, when they are illuminated on the truck the smae side on the trailer light goes off ! i think it might be a relay on the truck?
Old 04-11-2012, 09:03 PM   #4
truckdude239
Re: trailer lights
bad ground or the tailier light harness has gone bad samethign happened on our 03 zr2 s-10 new light harness and it fixed it
David fuller
2000 Tahoe 5.3l 378
Old 04-17-2012, 12:20 AM   #5
squirrely_1
Re: trailer lights
okay, replaced the trailer lights with a full replacement light/wiring kit, then replaced all the relays in my fuse box under the hood? The lights still go out when i hit the breaks, but the correspoding side will flash while holding break pedal if i have the turn signal on?
Old 04-17-2012, 08:29 AM   #6
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Re: trailer lights
Does your hazard switch work properly?
Believe it or not a ton of wires run through the hazard switch/multifunction turn signal/cruise/wiper/etc. switch. My brother was having a similar issue with the trailer lights on his truck. After tracing all of the wires, checking fuses, relays, etc. we swapped the multifunction switch with the known good one in my truck and it fixed the problem completely. The only sign something had been wrong with his switch was his hazard button was flakey.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 04-17-2012, 08:43 AM   #7
FrankieD
FrankieD's Avatar
Re: trailer lights
Try using a jumper cable to ground the truck to the trailer and see what happens. If that works then start tracing the ground wires. My car trailer would do the same thing and every thing checked out with the ohm meter it turned out the nut was slightly loose on the trailer for the ground wire.
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 04-18-2012, 05:15 PM   #8
G&R's57GMC
G&R's57GMC's Avatar
Re: trailer lights
I say hard wire the ground to all the lights on the trailer.
Don't rely on the trailer chassis for ground , especially on a boat trailer.
G&R's57GMC is offline   Reply With Quote
Thread Tools
Display Modes
