Old 04-13-2012, 11:13 PM   #1
HotRodScottsdale
HotRodScottsdale's Avatar
Can't find part
Fuel selector valve, lordco staff here couldn't find it and I chat fint it on any sites,any one know where I can find it
HotRodScottsdale is offline   Reply With Quote
Old 04-13-2012, 11:30 PM   #2
mattpiotr
Re: Can't find part
Friend of mine Had The Same Problem, Go to RockAuto.com i think he said it was round $113.79 for his 1975 Chevrolet C10 Fuel Tank Selector Valve
mattpiotr is offline   Reply With Quote
Old 04-14-2012, 08:48 AM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Can't find part
i bought mine at auto zone they had it in stock.... Lately i dont know what to make outta these chain auto part stores... i wanted new lug nuts 1/2 X20 you would think i was searching for the hope diamond and i still had to buy a set with locks and a extra card of four
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 04-14-2012, 11:01 AM   #4
broey
Square
broey's Avatar
Re: Can't find part
I got one from napa, had them in stock also.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 04-14-2012, 12:07 PM   #5
wyattglock
wyattglock's Avatar
Re: Can't find part
I got mine from NAPA. My local store didn't have it on their shelf, but the warehouse had them.
wyattglock is offline   Reply With Quote
Old 04-14-2012, 03:04 PM   #6
beamn7
Re: Can't find part
AC Delco part number U7000 has 3 ports that are capped off or U7001 has all 6 ports open.
http://webcaps.ecomm.gm.com/internet...e=22&part=6276
beamn7 is offline   Reply With Quote
Old 04-16-2012, 05:06 PM   #7
raceman6135
Dino burner
raceman6135's Avatar
Re: Can't find part
I thought Lordco carried or could easily get Standard Motor Products (aka Blue Streak) stuff ... if so, FV1 is the regular 3-port switching valve.
raceman6135 is offline   Reply With Quote
Old 04-16-2012, 07:19 PM   #8
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: Can't find part
yeah I had the same problem...
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 04-16-2012, 07:35 PM   #9
wyattglock
wyattglock's Avatar
Re: Can't find part
That was the same look I got when I asked for 9/16-18 lug nuts with one flat side, open so the stud threads all the way through. Thankfully my friend knew where they kept some in their old stock. Now I have the number for them and am working on a whole new set.
Old 04-16-2012, 10:31 PM   #10
Johnny Too Bad
Johnny Too Bad's Avatar
Re: Can't find part
Are you sure it's the selector valve that's bad? I thought mine was bad on my '78 and I couldn't find a six port anywhere. Turns out, it wasn't the selector valve after all, it was actually the selector switch on the dash that wasn't letting enough juice get through to engage the solenoid in the selector valve. Saved me about $100. Worth double checking if you haven't already.
1964 Chevrolet C10 SWB Stepside (350cid/TH400)
1978 Chevrolet C10 SWB Silverado Big 10 (454cid/TH400)
-"Ah, the pressure's fierce!"
Johnny Too Bad is offline   Reply With Quote
Old 04-17-2012, 12:25 AM   #11
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Can't find part
www.jcwhitney.com has them.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 04-17-2012, 02:18 PM   #12
hatzie
Moderator
hatzie's Avatar
Re: Can't find part
On the single wire 73-8? trucks... You can use a quality DPDT ON-ON toggle switch like McMaster Carr #7343K821 in place of the darn poor excuse for a switch that GM chose. You'll need to cut off one corner terminal to use the 5 position GM factory plug because the 6th hole is blocked.
This is the 6 port AC Delco solenoid valve.http://www.amazon.com/ACDelco-467513-Fuel-Selector... http://www.amazon.com/ACDelco-467513-Fuel-Selector...
Summit Racing lists the 3 port Standard Motor Products FV1.
Unfortunately the U7000 & U7001 as well as the valve listed for the 77 at Rock Auto are actually the later 1980s plastic 6 port Motorized Pollack unit. The motorized Pollack is not a drop-in unit. You'll need to replace/modify the entire tank switch and fuel gauge harness to make it work. Rock Auto is generally good to deal with but this should be noted in the information for this part...
Old 04-17-2012, 07:26 PM   #13
HotRodScottsdale
Re: Can't find part
What's the differnces between 3 port and 6?
Old 04-17-2012, 08:17 PM   #14
gchemist
gchemist's Avatar
Re: Can't find part
One tank or two tanks!
Old 04-17-2012, 08:28 PM   #15
HotRodScottsdale
Re: Can't find part
How can u tell the difference
Old 04-17-2012, 09:05 PM   #16
HotRodScottsdale
Re: Can't find part
There's a pic of it after I pulled it out
Old 04-17-2012, 11:52 PM   #17
raceman6135
Dino burner
Re: Can't find part
That looks like a 3 port to me.
One inlet comes from the driver's side tank.
One inlet comes from the passenger's side tank.
The outlet goes to the fuel pump mounted on the engine.
Old 04-18-2012, 06:26 AM   #18
88Jimmy4x4
88Jimmy4x4's Avatar
Re: Can't find part
is this what you need?
http://www.ebay.com/itm/GM-NOS-33455...sories&vxp=mtr
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 04-18-2012, 05:33 PM   #19
hatzie
Moderator
hatzie's Avatar
Re: Can't find part
3port switches supply lines.
6port switches supply & return.
Old 04-18-2012, 09:56 PM   #20
88Jimmy4x4
88Jimmy4x4's Avatar
Re: Can't find part
1991 GMC Jimmy 4x4
Old 04-21-2012, 10:10 AM   #21
Tucson38
Re: Can't find part
Ditto on this. I picked up a valve and switch from NAPA, replaced the switch first and that was the problem. Fixed it for under $10. Plus, it's a whole lot easier to swap out the switch than the valve itself.
Tucson38 is offline   Reply With Quote
Old 04-21-2012, 10:14 PM   #22
HotRodScottsdale
Re: Can't find part
Well I pulled it already and by passed it for now and I plan on renewing the whole system for that I just couldn't find the selector valve any where but plan on buying the Valle then the switch and wire all in at once, everything is slashed up with the wires on that truck so time for new all around I think
Thread Tools
Display Modes
