Old 04-13-2012, 11:57 PM   #1
RustyHunk-O-JunkGuy
Trans issues
If anybody has some ideas that would be great.
I got the "new" truck a couple of months ago and decided to swap in an automatic so the wife could drive it (no p/s or p/b). I figured I'd use the TH350 I had laying out back. "Hey it was a good trans and it's free!" Never mind it's been outside for like 6yrs. A basic Summit torque converter and a good clean out with a new filter later and we are in business. Back out the driveway head down to the gas station everything is going great. Go to grab reverse again and there is nothing, no forward gears, nothing. Shut the truck off, check the selector all good. Start it up and it grabs drive, make it part way down the street and it slips out. Shut it off and and it will get drive again, limped it home going straight through the stop signs because anytime you hit the brakes it slips out. I get it home, pulled the pan again and checked all of the spools in the valve body, everything moved and returned fine. Start it up and head down the street and it runs great and shifts fine! Three or four stop signs later and it won't shift out of first.Take it home check vacuum line, all good hop in again and now it slips like crazy again!
Next up I'm going to check the governer and maybe replace the vacuum modulator if that turns up nothing. Any ideas?
RustyHunk-O-JunkGuy is offline   Reply With Quote
Old 04-14-2012, 12:19 AM   #2
67c10rustbuket
67c10rustbuket's Avatar
Re: Trans issues
Sounds like vacuum line and/or modulator to me. Cheap and easy to replace, hopefully that will do it. I've had many problems with TH350s but not exactly what you have. Typically not shifting out of first gear is just a bad vacuum line or modulator. I would try those first.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 04-19-2012, 11:57 PM   #3
RustyHunk-O-JunkGuy
Re: Trans issues
So, replaced the vacuum modulator tonight. You no it's no good when fluid comes out the vacuum side. Got in the truck and test drove it. Works great! But wait... shift was a little off so I adjusted the modulator, all is well and a few stop signs later... Won't shift out of 1st again! If you pull it into Park then back to drive it will shift through the gears fine the first time then once it down shifts it won't shift out of first again. Any ideas? Only thing I haven't checked is the governor.
Old 04-20-2012, 09:00 AM   #4
snaus32
snaus32's Avatar
Re: Trans issues
hows your fluid level?
snaus32 is offline   Reply With Quote
Old 04-21-2012, 01:05 AM   #5
RustyHunk-O-JunkGuy
Re: Trans issues
It's right at the top of full hot.
Old 04-21-2012, 10:04 AM   #6
67c10rustbuket
Re: Trans issues
Yeah check out the governor next.
If you have a fluid pressure test gauge you could screw it into a port on the side of the case to check pressures to verify if the pump/seals are applying/holding the correct pressure in each gear, I bought one at a hardware store for like $50 when I rebuilt a trans.
Dan <---(my name)
Thread Tools
Display Modes
