04-15-2012, 09:28 PM | #1 |
55-59 (airbag) IFS
I've checked out numerous IFS setups for 55-59 Chevy trucks from several different mfgs. but can't seem to find one that suits all of my needs. Most of them either offer one or two options that I need (and or) want but not all the options and features I'm looking for in one complete package.
So I compiled a list of options, specs and general info. of what I'm looking for to see if anyone could help me out. -airbags (not Shockwaves) -power rack and pinion -Mustang II style -LS motor mounts etc. -standard disc brakes (don't care about fancy rotors) -significant drop built in (want the truck to lay body) -drop spindles -driveability (truck will be driven alot, and hard) -price If anyone can point me in the right direction where I can find all of these things in one package deal/setup, or if any (reputable) site supporters can make me one with all the features I'm looking for I would greatly appreciate it.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
04-15-2012, 10:00 PM | #2 |
Re: 55-59 (airbag) IFS
Have you talked to http://www.scottshotrods.com/frontends.asp they are a member on here.
04-15-2012, 10:58 PM | #3 |
Call Justin or email him. I did his super slam ifs on my burb and love it. It fits all of your requirements.
1 (805) 485-0382 justin@scottshotrods.com His knowledge and customer service is top notch. Juan Posted via Mobile Device
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
04-15-2012, 11:03 PM | #4 |
Here is a thread with my install. The mounting is a little diff for your truck but you'll get the hint.
http://67-72chevytrucks.com/vboard/s...d.php?t=497124 Posted via Mobile Device
04-16-2012, 03:59 AM | #5 |
Another one is http://www.nolimitparts.com/prodinfo...mber=WRIFS3-AB they are a member on here just let both know you are a member on here it might get you a good discount.
04-16-2012, 09:37 AM | #6 |
We are wrapping up a front and rear Dropmember kit for the 55-59 trucks.
Nate Posted via Mobile Device
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
04-16-2012, 09:57 AM | #7 |
i've been waiting to hear that nate....
04-16-2012, 10:37 AM | #8 | |
Scotts superslam ifs 2 x 4 sq 3/16 wall thickness on the crossmember one piece style for a easier installation. Our crosstubes that secure the upper and lower a-arms are made out of 1 1/8 1018 solid bar stock Upper and lower tubular a-arms made out of 1 1/8 round 1/4 wall dom tubing Our upper rodends for your caster and camber adj are made out of 304 s.s Spindals will be a dropped forged steel spindal power rack will be a BRAND NEW power rack with a lifetime warranty Boxing plates are included Bags will be a slam specialty bag shocks will be a monroe shock rack notches will come with the kit grade 8 hardware for all of your bolts brakes will be a 11 inch rotor bolt pattern will be a 5 on 4 3/4 or 5 on 4 1/2 your choice.We have 5 on 5 and 6 lug as well.Gm caliper with pads and our caliper bracket Our product is 100% tig welded sway-bar is included in the kit. We also have our Torsion splined bar as a upgrade Other parts you will need for your truck that we can help you out with Scotts L-s1 motor mounts Scotts drop out tranny mount Power steering line kit braided s.s line kit with banjo bolts Master booster pedal assy we have three choices you can get 1.Scotts frame mount pedal assy 2.Scotts under the dash pedal assy 3.Scotts firewall mount pedal assy We have master booster assy and we have wilwood manual masters to Wilwood pro valves wilwood res valves Brake lines kits for your complete frames Rear suspension we have our Scotts supersam 4-bar that will come with all your parts needed to do your install. 4 bar links 1 1/8 1/4 wall dom tubing right hand and left hand thread adjustment rodends are machined out of 304 s.s firestone sleeve bags all your brackets for your frame and rearens and upper shock mount box plates monoe shocks Scotts step notch Scotts frame mount fuel tank either a top fill or side fill setup for efi For interior parts Ididit steering columns Scotts coulmn drop Scotts floor mount Vintage air kits power windows power door kits lokar parts seats wiring kits for your truck radiators we have more parts as well. Bottom line we are a one stop shop and we can help out with all your needs you will need to make your project go smoother. On top of that we have GREAT forum deals for all of the members on this site. Feel free to call us up at the shop and ask us any question you might have.You can reach us at (805)485-0382 tech orders only (800) 273-5195 You can e-mail us to at justin@scottshotrods.com scotts@scottshotrods.com sales@scottshotrods.com jeff@scottshotrods.com Last edited by Scottshotrods; 04-16-2012 at 10:40 AM. Reason: add |
04-16-2012, 10:56 AM | #9 |
I'm not gonna spill all the beans yet... but our 55-59 Dropmember will allow the same results as the ones we currently offer for the C10 trucks. It even utilizes the C10 spindles and brakes.
Here's the only pic I will show for now.....
04-16-2012, 11:23 AM | #10 |
Check out our Wide Ride IFS packages, @ www.nolimit.net. Everything you want.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
04-16-2012, 10:27 PM | #11 |
Thanks for all the info, it definately helps. I'll call some of these vendors over the next few days and compare apples to apples and see which direction I decide to go. I'm hoping to purchase in a couple of months so I'll keep you guys posted, and probably start a build thread when I do.
04-16-2012, 10:42 PM | #12 |
Just got a different idea on running exhaust with this..........yeah we look at everything....lol............jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
04-16-2012, 10:53 PM | #13 | |
That was the only way we had room to go all the way out the back! Tight squeeze with all the components in place! Nate Posted via Mobile Device
04-17-2012, 07:36 PM | #14 |
04-17-2012, 07:47 PM | #15 |
^^^^^ I know some people are screamin holy C#@P now!!! Nate can U email me about panhard...jim...
04-17-2012, 09:22 PM | #16 |
That is sweeeet.........
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler 1968 Chevy c10 shorty Stepper (Patina LS project) 1967 gmc custom Long Box (Farm Truck Project) |
04-17-2012, 09:50 PM | #17 |
That's nice, I want mine a couple of inches lower though
04-17-2012, 10:02 PM | #18 |
Our frontend will lay your truck out on front and our rear suspension with our notch will lay you out.
We can set up our frontend to work with any size tire combo you choose as well. |
04-17-2012, 10:03 PM | #19 |
That's ride height!
This one has coil overs. Posted via Mobile Device
04-17-2012, 10:33 PM | #20 |
RUNNING OUT OF TIME
YOU GUYS ARE GOING TO MAKE ME TAKE OUT A SECOND MORTGAGE
1958 CHEVY SWBFLEETSIDE 1971 CHEVY SWB 1968 CHEVY SWB 1962 INTERNATINAL 1978 CHEVY SWB STEPSIDE -SOLD- 2003 CHEVY Z-71 2010 ESCALADE (WIFE'S) |
04-18-2012, 01:33 AM | #21 |
If i win the lottery im showing up at nates with a car hauler full of trucks and a suitcase full of cash lol.
04-18-2012, 10:36 AM | #22 |
how long till your pricing these kits?
need to know how much to put away! and will the kit work on a 56 sub? |
04-18-2012, 11:52 AM | #23 | |
I'm excited to post up some pics of the completed kit... it's pretty trick.
04-18-2012, 11:58 AM | #24 |
i better start saving my money now
04-18-2012, 12:02 PM | #25 |
RUNNING OUT OF TIME
I ALREADY WENT AND FOUND ME A THIRD JOB,
Thread Tools | |
Display Modes | |
