Old 05-08-2003, 04:32 PM   #1
Dropt72Shortbed
Dropt72Shortbed's Avatar
17x8 with 4.5" backspacing fit 72?
im gonna buy a temporary sent of 17s until i can spend the dough on 20s. ive got a good deal on the rims and i already have a set of 17" tires i can use.
the rims are 17x8 all around, 4.5" backspacing, is this the correct backspacing for our trucks? its a 1/2 ton 72.
Dropt72Shortbed is offline   Reply With Quote
Old 05-08-2003, 05:35 PM   #2
billogna
billogna's Avatar
I've got a '71 front end with 17x8s and '72 rear with 17x9s, both with 4.5" bs. I ground a little bit off of my bottom a-arms, though, can't remember why now, maybe rubbed when turning. The look of the offset is perfect IMO.
'69 Chev Cust/10 swb, 350/700R4, 5"/6"
'70 Chev C10 swb, 67 front, 454/700r4, 4"/5"
'73 Chev stepper, 350/3 spd
'84 Chev K20 350/4 spd
'91 GMC 1500 Suburban 4x4, 350/700R4
billogna is offline   Reply With Quote
Old 05-08-2003, 08:07 PM   #3
XXL
Seņor Member
XXL's Avatar
Re: 17x8 with 4.5" backspacing fit 72?
It depends on how dropped you are. They will work unless you're tucking tire or more... then you'll need to go with 5" bs or the fender will eat tires.
Kenneth
XXL is offline   Reply With Quote
Old 05-08-2003, 11:03 PM   #4
72chevyLWB
Got 20's????
72chevyLWB's Avatar
You can't go with more than a 4.5" bs in the back cuz you'll rub. What kind of 20's you looking for? I can get you an awesome hook up on Eagle Alloys.
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 05-08-2003, 11:16 PM   #5
brad2
I put a 20x9.5 with 5 inch back spaceing and a 295/40/20 on the back of mine and it didn't rub.
74 swb
71 2wd Jimmy
82 2wd Blazer
brad2 is offline   Reply With Quote
Old 05-08-2003, 11:31 PM   #6
XXL
Seņor Member
XXL's Avatar
I'm using 5" bs on mine and no rubbing.
Old 05-08-2003, 11:59 PM   #7
Glen
I just ordered two 17x8 4.5"bs AR Torque Thrust II's and 20x10's for the rear. The truck is already bagged, the rear will get a bridge as soon as the wheels arrive to keep it level and tuck the 20 up high in the bed.
This pic was taken about a week ago when I was sizing up the front wheels, this is a 17x8 with 4" backspacing, the tire was a 245-45-17, the tire went up in and my crossmember hit the same time my tire rubbed the fender. So I ordered my 17's in a 4.5" bs.
Glen is offline   Reply With Quote
Old 05-09-2003, 12:13 AM   #8
Glen
Here is that pic
Old 05-09-2003, 12:20 AM   #9
grnddwn
belly dragger
grnddwn's Avatar
I changed mine to a 4.25 bs this year but I ran 4.5 on my last to sets of rims
grnddwn is offline   Reply With Quote
Old 05-09-2003, 02:27 AM   #10
Dropt72Shortbed
ok i got two contradicting answers here
XXL your saying 4.5" wont tuck (yes my truck is going to be bagged, so i cant have it rubbing on the fenders)
Glen you're saying 4.5" works fine on a 17x8 with 245/45/17?
anyone else got any info?
i plan on buying a temporary set of 17s and need to know soon.
Old 05-09-2003, 07:59 AM   #11
XXL
Seņor Member
XXL's Avatar
Yep. I'm running 17x8 x5" bs and a 255/50/17 tire. I started with 4.5" bs wheels and they rubbed (just in the test fit... I wasn't even driving, which I suspect would be worse). I then went with 5.5" bs, but the rears rubbed (stepside bed)... so I went back to 5" and a 5/16" spacer on the rear. I've been running this setup for 3 1/2 years now and don't rub either up or dumped.
Kenneth
Old 05-09-2003, 03:46 PM   #12
Dropt72Shortbed
bump
Old 05-09-2003, 08:23 PM   #13
grnddwn
belly dragger
grnddwn's Avatar
when I had the 4.5 bs they tucked like a mofo. bagged out it looked like I hah no wheels from the back
Old 05-10-2003, 12:50 AM   #14
Glen
Sorry for the late reply......I just got in from work, please dont take my measurements as the rule. Iam just getting started on my 68 project and these other guys have been around this stuff much longer than I have been.
Thread Tools
Display Modes
