Old 04-20-2012, 05:06 PM   #1
Fastest32
Fastest32's Avatar
Has anybody cut 2 coils off the front?
I am about to cut the front coils on the front of my 64 longbed in the morning and I see almost everyone who does that usually cuts 1.5 coils. That was the original plan, but Im so tempted to cut 2. I guess I can always go back and cut more. Just wondering if anyone has pics of a truck with 2 coils cut. Will I need to remove bump stops either way? Any info will help. Thanks.
Fastest32 is offline   Reply With Quote
Old 04-20-2012, 05:44 PM   #2
Indian113
Indian113's Avatar
Re: Has anybody cut 2 coils off the front?
How old and settled are your springs now?
You can start at 1 coil and cut more if needed- it's hard to put a coil back
Indian113 is offline   Reply With Quote
Old 04-20-2012, 05:58 PM   #3
Fastest32
Fastest32's Avatar
I guess theyre the original springs. Im gonna just do 1.5 and see how it looks
Old 04-20-2012, 07:58 PM   #4
Indian113
Indian113's Avatar
The reason I asked that was I checked and my springs had settled 2 inches. I think LMC has a chart that tells ya what the ride height should be with stock springs.
Old 04-20-2012, 08:39 PM   #5
jonathan-m
1.5 is recommended as the lowest you can go without beginning to degrade driveablility. any lower and the drive would be noticeably worse. I did 1.5 on mine and removal of the bump stop bracket was definitely necessary.
Rockin' a '66 and loving every minute of it
jonathan-m is offline   Reply With Quote
Old 04-20-2012, 09:11 PM   #6
Fastest32
Fastest32's Avatar
Thanks guys. I'll do 1 1\2 and cut the bump stops.
Old 04-20-2012, 09:24 PM   #7
Goat herder
I'd recomend starting with 1 full coil first. Drive it a bit until it settles, and if still not low enough, try a bit more. I ussually heat a coil to drop it that bit more but not sure if you have a torch or not. 2 coils will give you no drivability, and 1.5 gives you a pretty rough ride.
Goat herder is offline   Reply With Quote
Old 04-21-2012, 02:41 PM   #8
Fastest32
Fastest32's Avatar
I cut 1 1/2 and it came out perfect. I'll post pics later.
Old 04-21-2012, 09:24 PM   #9
lwb66step
lwb66step's Avatar
2 coils daily driver slammed and rides good I drove it 100 miles today on the interstate.
1966 LWB Stepside......SOLD
1963 SWB Fleetside.....Current Project
I hate all fords.
lwb66step is offline   Reply With Quote
Old 04-22-2012, 10:40 PM   #10
monolith
Zero Albedo
monolith's Avatar
Cut 1 1/2 on my 3/4 ton-love the ride
Baz
"Deserve's got nothin' to do with it."
66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467
65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432
65 Chevy Panel (former U.S.Navy truck)
64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348
64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now)
68 Dodge Charger
monolith is offline   Reply With Quote
Thread Tools
Display Modes
