Old 04-21-2012, 04:34 PM   #1
gag1025
Interior Backing Material
Is it better to use jute or the aluminum backing material? Someone told me not to use the aluminum backing material because it would form moisture on the aluminum and rot or rust the material it comes into contact with. Any thoughts?
gag1025 is offline   Reply With Quote
Old 04-22-2012, 11:42 PM   #2
youngrodder
youngrodder's Avatar
Re: Interior Backing Material
I used Dynamat down first followed by jute and then carpet..
No moisture issues.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 04-23-2012, 09:41 PM   #3
OKGMC4
OKGMC4's Avatar
Most of the aluminum products are sealed on the back with some sort of asphalt type material. If it's butted and taped pretty good should be fine. The jute is a guaranteed moisture issue if it's directly on the floor. I agree with youngrodder. Seal it then use the jute.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Thread Tools
Display Modes
