05-09-2003, 08:48 AM | #1 |
user # 2756
power steering gear box
My power steering gear box has developed a leak where the steering shaft enters the gear box. Is this seal and/or bearing replaceable? Isn't there a shade tree mechanic trick to stop these types of leaks with I believe tranny fluid?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
05-09-2003, 08:51 AM | #2 |
You will probably need to replace the seal because of the pressure in the box. Seals are available through NAPA and other suppliers. It is not too bad of a job with the box off.
Jim |
05-09-2003, 08:53 AM | #3 |
user # 2756
Thanks Jim I did not know if the seals were obtainable or replaceable.
Jim
05-09-2003, 09:00 AM | #4 |
Go ahead and buy the GM overhaul manual. It shows how to rebuild differentials, transmissions, steering boxes, and AC compressors. All of the things that are NOT in other books. I have 2, a 68 model year and a 72 model year. Best books I own...
05-09-2003, 09:20 AM | #5 |
user # 2756
I had planned on by one from Kingparts a year ago and never did. Looks like I will now. Thanks,
Thread Tools | |
Display Modes | |
