04-22-2012, 11:22 PM | #1 |
Truck and auto performance nut
LSX - parts for a carb'd LSx and more for sale
Yes, with the efi change....unfortunately my lightly used carb'd LSx parts are for sale... to fund a new 4L85e electronically controlled transmission to replace my 200-4r. All parts are priced for local pick up. If you need it shipped, you pay shipping... but at least I don't charge for boxing it up!
GMPP LSX intake - SOLD MSD 6012 w/MAP sensor w/approx 10hrs use or less -SOLD Holley Street HP 750cfm carb - SOLD Lightly used Holley 4150 - 650cfm / electric choke / vacuum secondaries - $265 Rochester q-jet - remanufactured carb used just a couple of months - been sitting for a few years $175 NIB Summit 140gph/14psi fuel pump - $75 2 - AEM analog UEGO a/f gauges - $120 '09 LY6 exhaust manifolds - right side ground near flange - $50 for the pair w/shields lightly used set of Trend 7.375 chrome moly pushrods - $65 NIB Cloyes LS1 timing set and gears - $25 NIB 14" spun aluminum air cleaner w/filter -SOLD NIB TCI Turbo350 filter and gasket - $10 new front disc brake lines - $20 L&R '72 front disc brake setup. Includes everything from spindle to dust cap and these are in great shape w/good pads and bearings repacked, just bolt on and go - $80 - too heavy to ship '68 pedal setup - $20 '72 evap canister - $5.00 200-4r Hughes deep aluminum pan -currently still installed - $140 (SALE PENDING) TCI 200-4r Billet Servo kit - $120 (SALE PENDING) 200-4r Holley TV cable corrector/adapter and TCI cable bracket for Holley - $35 200-4r trans mount dipstick by Lokar - $50 (SALE PENDING) 200-4r - w/TV cable and 2200rpm converter - $400 - or $650 w/Hughes pan and TCI billet servo: (SALE PENDING) Also have other '67-'72 parts like radiators, radiator shrouds, visors, Holley tuning kit - Holley jets and squirters, etc.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 06-13-2012 at 08:34 PM. Reason: update |
04-22-2012, 11:41 PM | #2 |
Re: LSX - parts for a carb'd LSx and more for sale
Do you have any more info on the tranny? Also do you have any idea what shipping would cost to 85745? I'm very interested in tranny with the pan and the bracket for the carb.
thanks, ulises |
04-23-2012, 12:20 PM | #3 |
You mention trans, pan (the steel one?), and bracket. Does this mean you are not interested in the TCI servo kit, TCI/Holley cable corrector, and Hughes aluminum pan? Or am I misunderstanding and your interested in it all?
Trans was built by local racer/transmission shop owner for 500+hp and it holds my LSx fine in 1st and 2nd but seems to slip into 3rd/4th (could just be the torque convertor). So rather then running it in auto (it shifts too early) and unless I'm just put-putting around... I generally shift it manually and it does fine. Depending on how much power your motor has you may want to freshen it up before installing. I have no idea what shipping would be, but when I sold my 383 the guy had it picked up by a contractor that advertises in craigslist and pulls a 20-24ft trailer. He had a early 50's truck on it already plus a few other items with more in the back of his truck. Evidently from what he said there are lots of guys that do this. They schedule trips and offer space on their rides to others by the mile. Much cheaper then standard shipping from what I understand.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
04-23-2012, 02:35 PM | #4 |
Interested in the intake - what's the part #? It looks like its got some scuffs in the pics - are those just light scratches?
Thanks. |
04-23-2012, 05:13 PM | #5 |
If you're talking about pic1 then yes...it came with a few light scratches on it. Never bothered me. Its a genIV dual plane intake for standard deck height motors...and a rare beasty. #19244037
04-23-2012, 10:50 PM | #6 |
Moderator
I'd like to get in line on the Carter pump, please let me know if the sale doesn't go through. And the filter on the left in the pic if it's for sale.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
04-23-2012, 11:09 PM | #7 |
OK Leevon....you're next on the Carter. Sorry the Trick Flow canister filter is no for sale tho.
04-24-2012, 02:05 PM | #8 |
Update - Carter pump SOLD
I realized I could add some parts for those rebuilding an older LSx or wanting to add VVT to one.....Want to freshen up the valvetrain on an older LSx motor? Pulled from a "new" '09 LY6 w/0 miles. Stock LY6 beehive valve springs w/retainers and keepers - Stock LY6 push rods - Stock LY6 VVT cam (could be used w/o VVT - I'll try to get specs) - package deal for $100
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 05-09-2012 at 02:24 PM. |
04-25-2012, 09:34 PM | #9 |
carter pump has been sold.
04-26-2012, 02:20 PM | #10 |
OK guys.....need to move most of this stuff quickly to fund my trans.
Willing to make a "package deal" on the LSx stuff...for even more savings!!!!!! Just let me know!
04-27-2012, 07:22 AM | #11 |
Will you ship those spindles? Area code 46227?
If so I'd take them, with the brake lines and the holley tune up kit. PM me price. |
04-27-2012, 11:59 AM | #12 |
how much for the poly. bushings ship'd to 28036?...thanks billy
04-27-2012, 12:37 PM | #13 |
Whats the deal with the tranny, is it sold? Mileage, rebuilt, etc? Assuming all of the above is in good shape/realtively new I'll take it, would need to chat about the pan.
www.tomthetruck.blogspot.com <-- Aka build thread. Last edited by Tmwoodall; 04-27-2012 at 12:45 PM. |
04-27-2012, 02:09 PM | #14 | |||
04-27-2012, 02:34 PM | #15 | |
www.tomthetruck.blogspot.com <-- Aka build thread. |
04-27-2012, 06:33 PM | #16 |
jmwhite...
v6togo.... I PM'd both of you. Tmwoodall....Supposed to finalize today....you're 1st in line!
04-27-2012, 06:54 PM | #17 |
Understood. I'll hang tight
04-30-2012, 06:14 PM | #18 |
well.....been since 4/24 that uno67 has been on the site. Hopefully he's just been busy or something and not missing for a more serious reason.
So..... Tmwoodall.....how long should we give uno before moving forward?
04-30-2012, 08:00 PM | #19 |
I actually just blew my transmission money on a rear Wilwood kit this afternoon. I assumed this was sold. If I knew it was just the torque convertor I'd pony up on this too but not enough cash to now take the "chance"
Good luck with the sale.
04-30-2012, 08:48 PM | #20 |
Oh well....n/p...if its still available when you find some more funds you can try again then.
05-03-2012, 08:20 PM | #21 |
Package deal - *closed*. Fire sale deals over...ordered the new trans already.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 05-06-2012 at 12:00 AM. Reason: *edited - |
05-06-2012, 08:07 AM | #22 |
Does the MSD box care what crank reluctor wheel is in place?
05-06-2012, 02:20 PM | #23 |
Yes...there are 2 models. The 6010 covers 1x cam/24x reluctor genIII LS1's and some early LS2's. The 6012 covers 4x cam/58x reluctor genIV L92, LY6, LS3 etc.
05-09-2012, 02:21 PM | #24 |
For anyone using a used LSx with some miles on it....to freshen it up a bit I have like new valvetrain components to freshen up an older high mile motor. I reduced my price for the 0 mile '09 LY6 6.0L beehive spring set, retainers, and keepers, pushrods, and the cam.
$100 for it all, plus shipping. Also......200-4r deal did not go thru...so the 200-4r and/or its performance parts still for sale!
05-10-2012, 12:36 AM | #25 |
60-66 Nut
I'm interested in the spun aluminum air cleaner. Could I get a shipping cost to 83815 (business address) if shipping with UPS or FedEx, or to 83835 if shipping with USPS. Thanks
Thread Tools | |
Display Modes | |
