04-25-2012, 10:32 AM | #1 |
Finishing Frame/ Removing Cab
Hey everyone me again!!
Two Questions: How does everyone remove there cabs, light enough to lift for me but the wife struggles a bit. Also my frame on my 4400 is fully rebuilt to original spec, I will be using a 350/t400 combo. Should I be adding some bracing or boxing the frame anywhere? Thanks Shane
Australian GM/Holden Dealer 1937 Chev Rod - LS1/4L60E 1949 Chevy 4400 Dually - 235ci/4L60E 1958 Chevy Apache Fleetside SBC/T400 |
04-25-2012, 10:52 AM | #2 |
Stalker Nate
Re: Finishing Frame/ Removing Cab
A bare cab? Just a couple guys usually. A complete cab..then the Bobcat works best
1957 GMC SWB stepper modified summer time driver 1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project 1965 Chevy P10 Ice Cream Truck project Instagram - TheDonutDiner FaceBook - @UscreamIscream |
04-25-2012, 01:03 PM | #3 |
and a few others
Here's two ideas for lifting the cab....
http://67-72chevytrucks.com/vboard/s...d.php?t=419910 or.... http://67-72chevytrucks.com/vboard/s...d.php?t=346948 the second one won't work if you're leaving the doors on.
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
04-25-2012, 04:02 PM | #4 |
4 guys and a 6 pack always worked for me.
even with access to a forklift i use 4 guys
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
04-25-2012, 05:05 PM | #5 |
It depends on what you have access to. I've slid cabs from one truck frame to another by myself using a pair of planks before. I've also slid planks under a cab, jacked the frame up high enough so that after I blocked the planks up and let the truck down I could roll the frame out from under it.
lately I've used my chain hoist and a web strap to lift a cab. I wouldn't try to do it with two people as that will get someone hurt and if you get some friends over to help, no beer until the cab is off and setting on what ever you plan on setting it on. Both of the ways of using a cherry picker that 63 64 Bowties showed th links for in post three should work great if you have a flat floor with enough room to move the cherry picker around. |
04-25-2012, 05:11 PM | #6 |
the second one won't work if you're leaving the doors on.[/QUOTE] I built and use this one, however I made mine out of 2x6 instead. |
04-26-2012, 09:51 AM | #7 |
Thanks guys, the "Cherry Picker" will suit me perfect!!
How about my other question?? is there anything I should/could do to the chassis? thanks Shane
04-27-2012, 07:02 PM | #8 |
what??? that is what keeps it exciting...
Thread Tools | |
Display Modes | |
