04-25-2012, 05:08 PM | #1 |
Sticky steering wheel
I figure here come the jokes, but.....
Truck sat up for a couple of years with the back window busted out. Had a tarp over it so no rain got in the truck, but was damp enough to mildew a little bit in a couple of places. Steering wheel is sticky now. I've tried cleaning it with regular soap/water, 409 etc, then I saw a wheel for sale that said "not sticky" so I'm wondering if this is something that happens to the old GM wheels? Anybody got any idea what I should use to get it cleaned up? |
04-25-2012, 05:13 PM | #2 |
Re: Sticky steering wheel
What year truck/steering wheel? My understanding is that the material is breaking down and this causes the wheel to be sticky, you can try something like a 3M prep wipe on one small area of the wheel and this should remove the sticky feel.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
04-25-2012, 05:14 PM | #3 |
78 Big10 454
I've had great success with 3m Adhesive Remover. However, I would try saddle soap for starters. If that doesn't work, go to 3M.
1978 Chevy SWB C-10 2WD 454/400 |
04-25-2012, 05:30 PM | #4 |
90 percent rubbing alcohol has worked well for removing the sticky stuff on my 75 model.
Stock 75 C10 step side. 350 2 BBL, 350 trans. 150K miles. |
04-25-2012, 06:04 PM | #5 |
I used skin so soft on mine and it worked pretty good!
Posted via Mobile Device |
04-25-2012, 09:22 PM | #6 |
My 78 had the sticky whell really bad, I cleaned it good and bought a cheap string cover for it. No more sticky.
04-25-2012, 09:30 PM | #7 |
what did you use to clean your wheel?
04-25-2012, 11:04 PM | #8 |
used a ton of Armorall in several coats...then the good old wheel wrap just like the old days....
04-25-2012, 11:37 PM | #9 |
04-26-2012, 08:18 AM | #10 |
my 76 wheel is sticky too, glad we have this thread
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
04-26-2012, 08:30 AM | #11 |
i just used hot soapy water and dish detergent on my 77
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin 79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s 81 mercedes 300d 25 MPG 77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded" 73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091 '77 chevy trucks. built to stay tough. life is short build a hot rod |
04-26-2012, 09:46 AM | #12 |
78K & 79C Jimmys
spray nine
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
04-27-2012, 01:25 AM | #13 |
Sometimes an orange degreaser will work wonders.......newer high end detail shops stock it.
I would recommend the orange degreaser on everywhere you can get to.....then follow up with what we used to call "milk" It's very similar to armor all......but its far less greasy and reconditions plastics and old vinyl rather well. Posted via Mobile Device |
04-27-2012, 07:36 AM | #14 |
I wiped down my entire interior with paint thinner, it cut years of that nasty black gunk with no effort at all.
04-27-2012, 09:02 AM | #15 |
I tried the rubbing alcohol yesterday...didnt work on mine
04-27-2012, 07:28 PM | #16 |
425hp409
I have found that Napa "Carpet & Upholstery cleaner" works well with a couple of applications.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
04-27-2012, 09:41 PM | #17 |
you might could use some adhesive romover. i've use acetone paint thinner. it works good. don't use mineral spirits,it'll just peez you off.
04-27-2012, 09:58 PM | #18 |
Old Heap Driver
I fixed mine by replacing it with a 62 Chevy wheel. LOL
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
04-28-2012, 06:18 PM | #19 |
Orange hand cleaner, then soapy water, clear water to clean off the grit.
04-28-2012, 09:30 PM | #20 |
had this happen to me before on a truck i had a long time ago...plain ol' prep-sol worked perfect...as it does for many applications
04-29-2012, 09:23 AM | #21 |
Hot soapy water and a scrub pad worked for me. (soap that will de-grease like Dawn).
If I can wipe it down with a cleaner and paper towel, and the paper towel is black or brown, get the bucket and elbow grease. When I think it's clean enough, then I'll go back to the spray bottles of "stuff" and paper towels. I won't hesitate to try other stuff (lacquer thinner, mineral spirits, carb cleaner, alcohol...) but soap and water is cheap and effective.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. |
04-29-2012, 05:21 PM | #22 |
Thanks, that worked for me. Took several wiped downs but finally got all the stickiness gone
05-04-2012, 06:31 AM | #23 |
With all these suggestions,have they worked to keep it from getting sticky again?I've cleaned with a lot of things but the sticky always comes back.
05-04-2012, 10:21 AM | #24 |
Clean with orange hand cleaner, wash off with wet rag, repeat, dry off with dry rag, install 2 perforated steering wheel wraps (the thicker foam backed kind) to build up steering wheel diameter to newer style thickness and keep steering wheel cooler in the hot weather. The steering wheel cover will get dirty if your hands are dirty, and sticky if your hands are sticky/greasy/oily, but you can clean the steering wheel wrap the same way with orange hand cleaner and you are back to a clean wheel.
05-04-2012, 11:07 AM | #25 |
special k, I've used a bunch of different methods and prep sol seems to work the best like bigarmzz said. But it always came back. Just guessing but the wheel seem to be releasing some of the petroleum that it's made with mixing with the oil from skin causing it to stay around.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
Thread Tools | |
Display Modes | |
