Old 04-29-2012, 12:09 AM   #1
davepl
davepl's Avatar
How to remove caliper boot?
I'm about to rebuild a set of '72 3/4-ton front brake calipers, and I've got the piston out but the whole setup is a little different than what I'm accustomed to.
How do you get the piston "dust boot" off? I don't mean the square cut seal, I mean the boot that protects it from dust and moisture. Normally I've seen there's a "boot ring" around the outside that holds it on, but in this case it looks like it's pressed in with a metal ring.
But since I don't know for sure, I don't want to start driving out unrepairable pieces of my caliper!
Thanks,
Dave
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 04-29-2012, 05:56 AM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: How to remove caliper boot?
its been a while since i did one but if i remember i use a pick and pulled them out
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 04-29-2012, 09:00 PM   #3
hayhauler71
hayhauler71's Avatar
Some calipers I have rebuilt the dust boot pounds in like a normal seal. First make sure you can get the dust boots then take a look at them should be straightforward
Fuzzy
hayhauler71 is offline   Reply With Quote
Thread Tools
Display Modes
