04-29-2012, 03:05 PM | #1 |
Upgrading to 5 speed
As I'm cruising down the highway I look down at the tach and contemplate how nice it would be to have one more gear to lower the RPM's.
I currently have a 4-spd SM465 mated to a 205 transfer case. Is their a quick and easy bolt in 5 speed trans or trans and transfer case combo that can be used to upgrade my current equipment?
1968 K-10 Pretty Much a Stock Rust Bucket
04-29-2012, 05:03 PM | #2 |
Re: Upgrading to 5 speed
Oh i know how you feel, I have a 4 spd manual in my truck and i swear if i go past 55mph the engine will blow up. Im in the proccess of getting a RAMJET 350 which is basically a small black V8 and putting a T5 tranny on the back. Its a 5 speed, 1-4 is normal gearing and the 5 is an overdrive gear for highway driving that way you can keep the RPM's low. I dont know too much about this transmission but im in the proccess of learning more about it my mechanic. Im not to familiar with transmissions, just my 2 cents. Ill check back if i can come up with anything else.
1986 GMC K15 4.3V6/SM465/NP205 will be converting to 5.3LS E-ROD/AA adapter/SM465/NP205 10 Bolt Axle Rebuild Tutorial: http://67-72chevytrucks.com/vboard/s...d.php?t=536415 |
04-29-2012, 07:37 PM | #3 |
What transfer case are you mating it with? Just looked at one on ebay. Looks like the shifter is near the back. Do you have bucket seats or do they make a linkage kit?
04-29-2012, 10:21 PM | #4 |
You could go with an NV-4500 or NV-3500 or install a gear vendors overdrive. I wouldn't trust a 4x4 t-5 because as far as I know they were in the s-10 blazers behind a v6.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
04-30-2012, 01:50 AM | #5 |
T-5 in a 4x4? not my first suggestion although it works great in my iroc lol as far as 5spds go look for the nv5600 or get the zf-s650 6 spd if you can afford it or re-gear the truck
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
04-30-2012, 09:49 AM | #6 |
With the NV 3500, 4500 and 5600 it looks like the shifter comes up further towards the back. Won't that become an issue with the bucket seat? Would I stick with the 205 transfer case or would I need to mate it with a newer version. I'm really looking for an easy, yet reliable plug and play 5 spd that I don't have to make drive line mods. I'm in a remote location with no easy access to outside supplies or vendors.
I use the truck to haul loads of firewood, gas cans, propane and supplies to a remote location. Trips start out on the highway and end on a 4x4 trail with loose and often snowy conditions.
04-30-2012, 11:47 AM | #7 |
no swap like this is so much 'plug and play' it is going to take some fab and effort (not that you're not willing to put in the effort!)
great thread documenting a NV4500 install: http://67-72chevytrucks.com/vboard/s...d.php?t=431033
Current: 1971 K10 lwb Past: 1972 c10 lwb 1969 c10 swb 1977 c10 lwb more old jeeps than I want to remember! |
05-04-2012, 03:50 PM | #8 |
What is your final drive ratio? What engine? My 67 has a 250 and 4.57 final drive ratio. The best thing I did for highway rpms was put on a cherry bomb that we found in a junk pile.
In all seriousness though it would be nice to get a nv4500 but on the other hand I could buy a lot of gas for what that swap would cost. Unfortunately there is no simple solution besides just putting up with it. There is also the option of a ranger 2 speed auxiliary transmission that goes in between the engine and transmission. You'd then get a .75 overdrive and the ability to split shift with a heavy load like an old highway tractor. But then there's the issue with relocating your transmission and transfer case shifter plus lengthening your front drive shaft and shortening your rear one. Posted via Mobile Device
Currently truckless, previous trucks: 67 K20, 87 K10 aka V10 & 72 C10 |
05-08-2012, 01:46 PM | #9 |
Is your truck a manual or a automatic? If yours is a manual we got the same exact setup. I know for fact we have the same transfer case. I was doing some more research on that transmission and you all are right, on the T5 the shifter is not in the right place and i dont know how well itll be able to handle all 400lb of torque from the engine. So now im back to square 1. Have you had any luck on finding something? if so let me know ha
05-08-2012, 03:10 PM | #10 |
Seeing as its found behind o so many 3rd gens including mine go to thirdgen.org they will most likely have the most information on a t5 and what it can and cannot do
05-09-2012, 10:08 AM | #11 | |
Posted via Mobile Device |
05-09-2012, 10:15 PM | #12 | |
K5Camper
A NV4500 is the best choice for the swap. NV3500's are not as strong and they lack the Granny gear the 4500 has. No it's not plug and play. But if you are out in the boonies I sure wouldn't want T5 or 3500 trans being the weak link. I've wheeled in DirtyLarry's K10 before and after his 4500 swap and I can say when done right like he did, it's bulletproof. By the way, the shifter for a NV4500 is pretty close in location to the sm465. Meaning you don't need to have bucket seats to run one.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
05-10-2012, 12:03 AM | #13 |
So it looks like I need to start searching for a NV4500 to take the place of my SM465. I need the granny gear for going down my driveway, especially when I have a load. What vehicles used the 4500 and what transfer case were bolted to them? I'm thinking I will have better luck looking for a vehicle that someone is parting out and maybe pick up a NV4500 with the transfer case already bolted up.
05-10-2012, 05:09 PM | #14 |
The NV4500 goes behind some deisel engines. The thread below has a guy putting one behind a 6.2 deisel so you know those things are bulletproof.
http://67-72chevytrucks.com/vboard/s...=381424&page=2
05-10-2012, 05:12 PM | #15 |
If you go with the go with the 205 transfer case its not gonna bolt right up. Most likely there will be some cutting involved. Take a look at this thread. Guy did a great job and has tons of pictures and info. check it out
05-10-2012, 11:24 PM | #16 | |
K5Camper
4500's weren't ever offered in Square bodies. They were offered in the next gen of GM trucks (gmt400's) from 92-99. Some of the early GMT800's had the nv4500 an option behind 6.0l gas engines too. Problem is with either, the t-case drop is on the wrong side for a square body. One other option for a t-case that would bolt in would be a 241 from a 88-91 1 ton. It is a chain drive case, but they have been known to still be fairly strong.
Thread Tools | |
Display Modes | |
