Old 04-29-2012, 09:45 PM   #1
mooseknuckles
mooseknuckles's Avatar
rad hoses?
so what's everyone using for rad hoses???...I have a lower hose for a silverado on my lower, but the upper is a prob with the outlets on the rad on the same side.....and I'm gonna be using a f-body pump.......
mooseknuckles is offline   Reply With Quote
Old 04-30-2012, 09:45 PM   #2
6.0 1955
Re: rad hoses?
Take a coat hanger and bend it to shape and lengh you need. Then take the pattern to the local parts store and see if the bends you need are in one of the in stock hoses. You may have to buy a longer hose and cut it off to get the correct bends you need.
6.0 1955 is offline   Reply With Quote
Old 05-01-2012, 02:15 PM   #3
mooseknuckles
Re: rad hoses?
good tip!....never even thought of that.
Old 05-01-2012, 03:31 PM   #4
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: rad hoses?
can't remember for sure...but think I used a 72/sbc lower? And a 6.0L truck (LQ4/LY6) upper.
with that double pass...you ought to run the intake to the other side?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-01-2012, 05:31 PM   #5
mooseknuckles
Re: rad hoses?
the air intake??...can't the alternator is in the way.....
Old 05-01-2012, 06:16 PM   #6
68GMCCustom
Re: rad hoses?
just have to go out and around. cut a small piece to take it out a couple of inches. still shortening it...haven't worked out the final layout yet tho.
Kurt -
Old 05-01-2012, 07:10 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: rad hoses?
Mine aren't on the same side, but if you have a decent relationship with your local parts guys, just ask if you can go through the wall of hoses yourself. I bent some rod in a rough shape, and went and found some cheap off-the shelf hoses to make what I needed. I added some stainless tube for a custom look, and more clearance on my fan and intake. You can do alot with stock parts.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-01-2012, 09:31 PM   #8
68GMCCustom
Re: rad hoses?
Thats what I was thinking I need to do for my upper hose to move it out of the way more.
Kurt -
Old 05-01-2012, 10:10 PM   #9
Dustytrix
Re: rad hoses?
I like that idea too.
Dustytrix is offline   Reply With Quote
Old 05-05-2012, 09:39 PM   #10
mooseknuckles
Re: rad hoses?
this is what I ended up doing.....
Old 05-05-2012, 11:57 PM   #11
68GMCCustom
Re: rad hoses?
I think if/when I replace my 4 core radiator with aluminum...I'll go with a double/pass like you've got there...with a coooler tho.
Kurt -
Old 05-06-2012, 09:15 AM   #12
mooseknuckles
Re: rad hoses?
yeah...I prob would've gotten the cooler in the rad, but they didn't make one,(special order).....but I'm kinda glad I didn't cause it's alot cleaner looking without it.....and my tranny coolers under the bed, which cleans it up too.....
Old 05-06-2012, 09:46 AM   #13
Daaaanz67
Re: rad hoses?
Hey mooseknuckles that f body pump bolted right up and all the pulleys lined right up or did you have to use spacers. I noticed you are using truck accessories. Also who is that air intake made by looks nice and clean along with your rad hose setup
Daaaanz67 is offline   Reply With Quote
Old 05-06-2012, 05:06 PM   #14
mooseknuckles
Re: rad hoses?
haha...you like that hose set-up?.......the cold air is a K&N...and if you notice the pump has a 4" wide pulley...so you don't have to use the spacers....and looks cool too...
Old 05-06-2012, 06:30 PM   #15
Daaaanz67
Re: rad hoses?
Who is that pump made by what part # or application is that intake originally for and more info on that radiator please might use some of your ideas if you don't mind .
Old 05-06-2012, 06:57 PM   #16
mooseknuckles
Re: rad hoses?
the pump is a PRW, I bought off of e-bay, and the k&n is from a 2004 silverado?....can't remember the part#...the rad is a griffin universal....pics in my build thread.....
Thread Tools
Display Modes
