Old 05-02-2012, 12:24 AM   #1
INSIDIOUS '86
INSIDIOUS '86's Avatar
Caster corrected tubular a arms
http://www.classicparts.com/1971-87-...nfo/74%2D157B/
If you have read up in the make it handle thread in the suspension forum you know that drilling the cross shaft on the control arms and moving them an inch forward is the best way of gaining much needed caster, but makes the coil spring kind of bind sideways in the upper and lower pockets.
Figured I would share with you guys
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 05-02-2012, 01:52 AM   #2
bucannon
Salty Sailor
bucannon's Avatar
Re: Caster corrected tubular a arms
will this help lowered and lifted trucks alike?
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 05-02-2012, 02:06 AM   #3
INSIDIOUS '86
Lowered especially. Lifted no since a lifted truck uses an axle not control arms
Old 05-02-2012, 12:35 PM   #4
bucannon
Salty Sailor
bucannon's Avatar
I should have specified, lifted with lift spindles
Savannah, Georgia
Old 05-02-2012, 03:55 PM   #5
INSIDIOUS '86
I believe lifted 2wd trucks use the longer 3/4 arms anyway so the half ton ones won't work
Old 05-02-2012, 05:16 PM   #6
bucannon
Salty Sailor
bucannon's Avatar
Yes they do, but they are the same size as 1/2 ton arms. just the ball joint is larger.
and i looked on the website and see they only appear to have 1/2 ton control arms
Savannah, Georgia
Old 05-02-2012, 08:07 PM   #7
INSIDIOUS '86
Well then I would say they indeed do work
Old 05-02-2012, 08:25 PM   #8
J Knight
J Knight's Avatar
Just to be clear, I didnt see any drop info in the link on the OP so these control arms are for performance and added caster, correct? If you installed with stock springs and spindles it would still be stock height?
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 05-02-2012, 08:28 PM   #9
INSIDIOUS '86
This should answer things. Found out cpp makes these http://www.classicperform.com/tech_a...bular_Arms.htm
http://www.classicperform.com/NewPro...ubularArms.htm
Old 05-03-2012, 02:50 PM   #10
bucannon
Salty Sailor
bucannon's Avatar
do they have them available in 3/4 ton?
Savannah, Georgia
Thread Tools
Display Modes
