05-03-2012, 04:15 AM | #1 |
Advice is needed, how to get my temp gauge working...
Ok, I need some advice on how to get my temp gauge to read. Only gauge that works right is speed, batt. No temp. How can I make it work, what to look for connection wise. Any advice is appreciated. Thanks.
Posted via Mobile Device |
05-03-2012, 09:54 AM | #2 |
Re: Advice is needed, how to get my temp gauge working...
I am suspecting you have a sbc? First I would look at the temperature probe on your engine and make sure the wire is on it. Or that it is not broken etc...
1981 C50 Conversion http://67-72chevytrucks.com/vboard/s...d.php?t=503247 1962 Grumman Olson http://67-72chevytrucks.com/vboard/s...d.php?t=613242 |
05-03-2012, 12:42 PM | #3 |
2 day insomnia had my brain, lol I forgot to say 84 305 swb. Can you tell me where it is on engine? Thanks.
05-03-2012, 06:34 PM | #4 |
Temp sender should be in the driver's side cylinder head. Should have a green wire connecting to it.
05-03-2012, 08:24 PM | #5 |
Yeah usually a green wire attached to the sending unit on the drivers side of the block, just under the exhaust manifold close to the #4 cylinder. One fairly ez check is attach the green wire to a ground, this should max out the gauge(key on of course), if your gauge maxes then it is the sending unit in the block that is toast. If touching the wire to a ground does not max out the gauge then it could be a break in the wire, fuse, or a faulty gauge.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
05-03-2012, 09:50 PM | #6 |
Thanks, guys appreciate.
05-04-2012, 09:41 PM | #7 |
I just read my post, should read #3 cylinder, musta hit the wrong key.
Thread Tools | |
Display Modes | |
