05-04-2012, 12:05 AM | #1 |
Daytime Running Light Questions
Hey guys, I have a 2000 GMC Yukon XL that's having some DRL issues. I've noticed that when one of the bulbs burns out, its ALWAYS the passenger side bulb. I got tired or replacing bulbs, so I replaced the OEM lights with a set of aftermarket LED parking lights. They lasted less than 3 months and then the DRL portion of the LEDs on the passenger side started to malfunction. Is anyone else having issues with their DRLs? Is it a wiring issue? Does anyone know how to resolve this?
1975 Chevy Cheyenne w/ v8 350 and TH350 Siverado interior Fleetside bed aka "The Beast" aka "Cheyerado" |
05-04-2012, 07:26 PM | #2 |
Re: Daytime Running Light Questions
dude you are preaching to the choir on this one! i have changed the light on my tahoe a million times. i think the culprit is a little water inside the lens case. and i think it bumps up and hits it? do you have any moisture in your lens case? i also notice other people right drl as well is out!
2001 Tahoe 1978 K30 |
05-04-2012, 08:08 PM | #3 |
the best way i found is to clean the bulb with isopropyl alcohol and use a very clean cloth to install the bulb. Bulbs that have any amount of skin oil on them will burn out very quickly. 4114 LL bulb is the fitment bulb #
Trueman |
05-04-2012, 08:18 PM | #4 |
Saturn had a huge problem with this issue on the ION. Engineering tried a lot of things. Ultimately a dropping resistor was installed for each DRL as the bulbs were simply overheating. Might be able to dig up the part number from your local Chevy dealer. Installed probably a hundred sets myself, but it was a kit that did not pay that much to install. So I don't have the number info handy, if at all. But it did look just like an old ignition ballist resistor.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
05-04-2012, 09:32 PM | #5 |
Thanks for the info guys. I currently have a set LED parking lights installed, so I'm not using the OEM lens or stock bulbs. I think its a set of Anzo LED parking lights. This is my second set, summit racing replaced them because they were still under warranty.
06-02-2013, 11:39 AM | #6 |
I am just taking out the drivers side bulb on my 2000 GMC Sierra so neither side works now.
06-05-2013, 06:12 PM | #7 |
Pull the fuse. problem solved. DTRL are unnecessary in my opinion. Mine did the same thing and I pulled the fuse.
If your not living on the edge...Your taking up to much room!! |
Thread Tools | |
Display Modes | |
