Old 05-04-2012, 09:31 PM   #1
Dave
DND Trucks
Smile 70's Motor Home Tilt
Here's a late 70s MH auto tilt column for sale. Tilt mechanism is tight and the shift bowl pin area for the gear selector isn't oval shaped, like a lot are. Item also has the correct length shaft and long style gear selector. Tilt and and cruise lever are included. Take a look at the pictures, some surface rust near the bottom of the column.
Great column to convert to a 69-72 truck tilt.
175.00 shipped CONUS.
Dave is offline   Reply With Quote
Old 05-05-2012, 10:41 AM   #2
Dave
DND Trucks
Re: 70's Motor Home Tilt
ttt.
Old 05-06-2012, 06:09 PM   #3
Dave
DND Trucks
ttt. I'll post more pics tonight.
Old 05-06-2012, 10:22 PM   #4
Dave
DND Trucks
More pics.
The wiring harness was taped up so I unwrapped it to see if there were any issues. None found. The gray wire has the connector missing. I can put the correct connector on it, prior to shipping. Lmk, if you have any questions.
Old 05-06-2012, 11:07 PM   #5
Dave
DND Trucks
ttt.
Old 05-07-2012, 06:40 AM   #6
Dave
DND Trucks
With everyone looking at this, I'll lower the price a bit to get it moving.
160.00 shipped CONUS.
Old 05-07-2012, 12:36 PM   #7
WIDESIDE72
WIDESIDE72's Avatar
I am interested. I have put the van tilts in trucks before and was not happy. THey worked OK, but I didn't like having to work with the neutral safety switch. What doe the motorhome tilt have to have to make it work in a truck? Do you also have an adaptr to go from the flast plug to the round for our trucks?
WIDESIDE72 is offline   Reply With Quote
Old 05-07-2012, 01:32 PM   #8
29od1
You can send it my way for $150 shipped. That'll get it moving
29od1 is offline   Reply With Quote
Old 05-07-2012, 04:56 PM   #9
Dave
DND Trucks
The steering shaft and the chrome gear selector arm are the correct length. However, the MH tilt has the neutral safety switch in the same location as the van. It will have to moved. I'll check on the adpater.
Old 05-07-2012, 05:00 PM   #10
Dave
DND Trucks
Smile Re: 70's Motor Home Tilt
Thanks for the offer, but I'm going hold at 160.00. The tilt mechanism is tight and the pin area isn't oval shapped. Also has the correct shaft length. No machine work required. Lmk.
Dave..
Old 05-07-2012, 05:02 PM   #11
29od1
I'd do it for $160 shipped if the other guy passes.
Do you know if the lower bearing is any good since it has quite a bit of corrosion down there?
Old 05-07-2012, 08:30 PM   #12
Dave
DND Trucks
Sold to 29od1, pending payment. Lower bearing is dry, probably needs to be greased. Sending pm.
Old 05-07-2012, 08:55 PM   #13
29od1
Hi Dave,
Money sent for tilt.
Thanks,
David
Old 05-07-2012, 09:08 PM   #14
Dave
DND Trucks
Payment rec'd already. Thanks again.
Old 05-07-2012, 11:47 PM   #15
WIDESIDE72
WIDESIDE72's Avatar
I got skipped. What gives?!
Thread Tools
Display Modes
