Old 05-05-2012, 09:07 AM   #1
88Jimmy4x4
88Jimmy4x4's Avatar
TH350 trans to radiator cooling lines questions
okay got my engine and trans in the 76 truck finally.......I bought new radiator cooling lines and Im not sure what line goes where. My GM manual says TH350 bottom connection goes to radiator and top connection comes from radiator.
My question is on the radiator is the top connection the inlet or is that the outlet/return to trans?
inotherwords.....does the bottom line on trans go to bottom of rad.....likewise top line on trans to top conn on rad or vice-versa?
I have searched the internet and have gotten mixed reults
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 05-05-2012, 11:37 AM   #2
badpontiacs
badpontiacs's Avatar
Re: TH350 trans to radiator cooling lines questions
I didnt think it mattered.
badpontiacs is offline   Reply With Quote
Old 05-05-2012, 11:47 AM   #3
Nothinghead
Nothinghead's Avatar
Summit labels them as what goes where and does what. I just bought some. I would imagine that cooler juice would be on the bottom of the radiator, thus the lower line would be coming from the radiator. That's just my thought process.
79 Blazer 350 TH350 part time 4wd Sold!
86 GMC 1 ton something...
Nothinghead is offline   Reply With Quote
Old 05-05-2012, 01:39 PM   #4
ron350
ron350's Avatar
On my 75 model the top radiator fitting connects to the top transmission fitting.
Looks like top to top and bottom to bottom.
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is online now   Reply With Quote
Old 05-05-2012, 02:09 PM   #5
kmfb
mine was top of tranny to bottom of radiator and vice a versa
kmfb is offline   Reply With Quote
Old 05-05-2012, 02:25 PM   #6
88Jimmy4x4
88Jimmy4x4's Avatar
Thanks guys, seems everyone is different lol
1991 GMC Jimmy 4x4
Old 05-29-2012, 01:17 AM   #7
GuyO
GuyO's Avatar
There is a couple of ways to tell which is which, generally the pressure side of the transmission is the line from the front of the transmission which goes to the bottom radiator connection (The other is to start a cold engine, place in Drive for 10 seconds to activate the transmission pump and shut off the engine. The cooler of the two lines is the return line which should be the top radiator connection). The top line is the return line which goes to the back of of the transmission. Good luck. G.
GuyO is offline   Reply With Quote
Thread Tools
Display Modes
