307 or 327?
Ok, so I have done work on 350's and 454 fords but I have never done a complete rebuild or anything like that. So by no means am I an engine guru. I just picked up a 68 Chevy C10 long bed and the engine is definitely smaller than a 350. I cannot figure out if this thing is a 307 or a 327. I've talked to a few guys around town who know a lot about Chevy's but one will say 307 and the other will say 327. I spent a lot of time yesterday trying to find the casting number or any number that will identify this thing and can't find anything. Is there a way to figure this out without ripping the engine out? I've read a lot of post saying where to look but have not had any luck.
It's obvious that the guy who had it before me has done some different stuff to it, so I don't really know what I'm working with. My goal is to have this be a daily driver so I don't have the luxury of having a machinist tear it apart to tell me all about it haha. Here's a pic if it helps. ![]() |
Re: 307 or 327?
Either the casting number behind the driver side head or the stamping with suffix code on the front block deck below the passenger head will tell you what exactly you have. You can check the numbers at nastyz28.com, they have a full engine decoding menu for casting and suffix codes for all GM V8s and also they tell you where to look for these (with pics) just incase my description is confusing. Or reply here with the numbers and one of us can tell you what it is. Good luck!
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
Re: 307 or 327?
The best thing to do would be to look up the block pad numbers. They should be as shown in the pictures unless they have been milled off during a decking operation. Might have to wire brush or even sand down through to the metal to see them. Tell us what you see as a picture can be really difficult.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Re: 307 or 327?
The second picture is exactly where I thought I was suppose to look, but there's nothing there. Do people sometimes take the numbers off? Why would they want to do that?
Re: 307 or 327?
Did you clean it down to the metal? The stampings will disappear under a heavy coat of paint alone, much less any gunk. There were numbers there in almost every case. The block may have been decked at some point as I said earlier. This is done to square up a block relative to the crankshaft centerline or after a sleeve sometimes. A long neglected head gasket might also justify a light pass to true up the head surface.
Re: 307 or 327?
Okay, thanks for the information. Now that I know for sure where it's suppose to be, I'll hit it with a metal brush to see if anything is there. There doesn't seem to be much gunk but it does appear to be painted. I'll let you guys know what I find.
![]() Join Date: Jan 2007
Re: 307 or 327?
If the block has been decked then the numbers may have been cut off but scrap the paint off first
Re: 307 or 327?
The best way is the casting numbers on the block, on the drivers side right below the head in the rear, my have to clean up back there and use a mirror , but the numbers are there
Re: 307 or 327?
So the front stamp says V0429WA... That means that it's a 307 right?
Re: 307 or 327?
I'm gonna guess 327, reason being I beleive the oil filler tube at the front of the engine was unique to the 327, could be wrong, but I don't remember ever seeing the filler tube on the front of a 307. Later, Lew
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart 1998 Chevy 1/2 ton ex cab V-6 5 speed 1967 Chevy SWB - project truck; not started just yet |
Re: 307 or 327?
V0429WA
Made in the Flint Plant on April 29th From what I see WA means it could be a 1965-283 1968-307 1969-350 My guess would be the 307 |
Re: 307 or 327?
Id get the number off the back behind the head on the drivers side. Thats how I checked and found out my 307 turned out to be a 327. Was pleasantly surprised
#13 | |
Re: 307 or 327?
#14 |
Re: 307 or 327?
I agree we need the casting #. Joseph
1970 Chevelle Nomad station wagon 1966 C-10 lwb,250-six,granny 4speed ![]() ![]() 1966 C-10 lwb,factory A/C,Custom Cab ![]() 1954 Delray 2-door sedan [rat rod project]
#15 |
Re: 307 or 327?
Agree, we need to see the casting number to nail down this application. Maybe even the casting date. Let us know what you find. No matter the effort it pays to know what you actually have under the hood.
Here is a site I like that has a lot of good information. It has really grown over the years. http://www.nastyz28.com/chevy-engine-code-stampings.php http://www.nastyz28.com/sbchevy/sblock.php
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 05-10-2012 at 02:01 AM. |
#16 |
Re: 307 or 327?
I wonder why you think you can tell it's smaller than a 350? They all look the same. Does it have the small harmonic balancer?
#17 |
Re: 307 or 327?
Yep mine says 3970020 and it's a 307... go to NastyZ28.com and bookmark it! Back of engine is hard to get to with the engine installed but will tell you all you need to know. Also can tell a lot from the size of the balancer on the front of the crankshaft.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#18 |
Re: 307 or 327?
I'll have to keep trying to see the back numbers. Maybe I'll try using a mirror or something. I can see where those numbers are, just not well enough to see the numbers. I'll get back to you guys and let you know what I find.
#19 |
Re: 307 or 327?
That's what you need,a flashlight and mirror.
#20 |
Re: 307 or 327?
Same here, and the oil filler intake can be put on any pre 87 SBC engine IIRC, so that's really means nothing.
It could be any thing from a 265 to a 383 or bigger even. |
#21 |
Re: 307 or 327?
Did anyone notice, that engine has later heads.......centerbolt valve covers. That engine could be anything cause I can tell it is put together from parts. Even if you get the casting number it will only tell you the size of the bore when the block was cast. 3970010 means a 4" bore and large journal, it probably will be a 350 but still can be a 327 (put a 307 crank in a 350 block....instant 327).
The heads have to be from 1987 and later due the centerbolts....but an earlier oil filler intake can be used on them if you slot the center four holes in the intake manifold.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
#22 |
Re: 307 or 327?
Yes, I figured it is some sort of a frankenmotor. But the best place to start is with the block. Then ID the other externals as required. We can ID the block, heads, intake and carb by the numbers and arrive at an as built spec for each. After 40 years anything is possible and actually even likely. I'd say probably less than 10% of the board trucks have an original (as delivered) carb..
#23 |
Re: 307 or 327?
I have no problem (really) with a frankenmotor. The only thing that makes things hard is not knowing what everything is. Makes it a little harder to work on haha. So let me ask you guys this, if you had this truck with this engine (and limited budget), would you just run it for now and save your pennies for a new engine and hope to find a good deal, or work on it one piece at a time?
#24 |
Re: 307 or 327?
If it runs with a reasonable level of reliability, then there is no immediate need to change it. Lets try and ID what you have and go from there. You get to do the dirty work, but learn as well. Somewhere along the line we will likely ask for the intake and head casting numbers. So if you see them write'm down.
#25 |
Re: 307 or 327?
okay, so quick question. My wife is due any day now so I don't have the time/money to tear everything apart yet. I would like to drive it the next couple weeks until I'm able to change out the 2bbl carb and steal intake manifold to a 4bbl carb and aluminum manifold. Main problem being is, I have no clue when the fluids were last changed. It's my understanding that it's been sitting for a minute so I want to change all the fluids. Radiator, oil, tranny, brake. Any recommendations on fluids to use or how I go about making sure I use the right amount of oil? I can assume that the dipstick is correct but I'd rather not assume anything with this truck. Any other recommendations?
Thread Tools | |
Display Modes | |
