Old 05-13-2012, 12:39 PM   #1
misternash2
LS guys: what are you doing for A/C?
i'm looking at what my options are regarding compressor mounts. i'd initially thought about fabbing up my own, as i've got both a 1988 compressor and the compressor off the 2004. i just thought i'd check around at what y'all are using.
i used the plates that use the old motor mounts. it's on an 88 suburban (2004 5.3) with rear air. everything else on a/c setup is stock.
misternash2 is offline   Reply With Quote
Old 05-13-2012, 03:19 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: LS guys: what are you doing for A/C?
You have options.
http://www.kwikperf.com/lsx_ac.html
Using stock parts use this option: http://www.maliburacing.com/forum/vi...hp?=34&t=79059
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 05-13-2012, 10:41 PM   #3
Jonboy
Slots go on anything!
I am using the Vintage Air kit, which uses a Sanden compressor. It is on my TBI engine right now, but will be mounted using the Kwik Performance brackets (purchased through VA). Dirty Dingo also has some nice looking A/C brackets as well, if you might be looking into the Sanden compressor.
1974 Jimmy- 5.3/4L80e/NP241
Old 05-13-2012, 11:08 PM   #4
chebyshortbox65
chebyshortbox65's Avatar
I'm using the factory mount on the lower right side with an express van compressor
chebyshortbox65 is offline   Reply With Quote
Old 05-14-2012, 10:14 AM   #5
rs72z
rs72z's Avatar
How does the lines exit on the van compressor?
I used the r-4 like on the malibu racing link above. The bad thing about going that route is belt selection isn't very good when you get that long of a belt.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 05-14-2012, 11:59 AM   #6
chebyshortbox65
Similar to the regular truck but the compressor is not varible displacement pump I notched my deal a little for the suction lone and used the factory a/c hoses from the express just added my fittings I also flipped my condenser upside down sunset they exited the drivers side now they exit the passenger side bottom only had to notch to core support a little.it gets down to around 46 but kinda warms up at idle I belive its because of the factory condenser I'm going to try a new hi flow up dated one and see if that helps
Thread Tools
Display Modes
