Old 05-14-2012, 12:21 PM   #1
brap999
brap999's Avatar
Parking Brake Connection
Since I bought my truck, my parking brake has not worked properly. I can pull the handle it it tightens up to the point I can't pull it anymore, but there is still not enough force to keep the truck from moving. The previous owner built a 'custom' bracket to connect the cable from the parking brake handle two the two cables to the rear drums.
After doing some research, I see why he attempted to build the 'custom' bracket', as it seems I'm missing the piece that connects the brake handle cable to the rear cables.
I attached a photo from the '63 shop manual which shows the piece I'm talking about.
Where can I get this? I've looked around but can't find it, though it might be because I don't know exactly what it's called or what I'm looking for.
Any ideas or suggestions how to get this thing working?
1963 Chevrolet C10 Stepside
1972 Pontiac GTO
1998 Dodge Viper GTS
1999 Jeep Cherokee XJ
2018 Chevy Camaro ZL1-1LE
It's never too early to beef up my obituary
brap999 is offline   Reply With Quote
Old 05-14-2012, 12:55 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Parking Brake Connection
To my knowledge, no one make this. You'll have to pull it off another truck.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-14-2012, 01:36 PM   #3
1963c-10
1963c-10's Avatar
I believe its called the parking brake equalizer.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-14-2012, 01:42 PM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Basically flatbar with holes drilled in it and a notch. Course you have to have one to make one.
Old 05-14-2012, 01:46 PM   #5
vin63
It's Better With Nitro
vin63's Avatar
Originally Posted by brap999 View Post
Since I bought my truck, my parking brake has not worked properly. I can pull the handle it it tightens up to the point I can't pull it anymore, but there is still not enough force to keep the truck from moving...
...Any ideas or suggestions how to get this thing working?
If you want to keep the stock style actuation, you'll have to fabricate that forward equalizer bar assembly...several of us have had to do that in the past, or go with an aftermarket solution from Lokar, etc. But, before you start dismantling everything, did you adjust the rear brake shoes? just have to ask since it is sometimes overlooked.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 05-14-2012, 02:34 PM   #6
1963c-10
1963c-10's Avatar
I have a 61 parts truck, I can see if theres still one in it.
Old 05-14-2012, 09:14 PM   #7
TR65
TR65's Avatar
This is off a 65 but I think it is the same as yours. Here is a picture so you can see what it was. I had to move mine so I just fabbed a whole new unit. Works good. Post #10 of my build thread has some more details. Good luck.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 05-14-2012, 09:35 PM   #8
'65 chevy lover
TR
Nice fab work! The e-brake set up from a 66 will also do the trick. I'm sure you already know that. Do you have the stock trans? Edit: Never mind, I noticed the build thread and read that.
'65 chevy lover is offline   Reply With Quote
Old 05-14-2012, 09:49 PM   #9
ABX131
ABX131's Avatar
Thanks for this post. I am going to have to address my parking brake issues soon and I will have to fab this unit.
ABX131 is offline   Reply With Quote
Old 05-15-2012, 02:11 PM   #10
MacAttack
283 Drama Queen
MacAttack's Avatar
TR
That is just TOO SICK!!!
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 12-20-2012, 12:43 AM   #11
702Badge
Hey guys..Im new to this. I just bought an old '63 chevy 4x4. The parkign brake handle under the steering wheel appears to be fully functional. The cable is connected to rear drums and looks ot be intact. My issue is that the cable is just through the fire wall with the u bolt thingy on the end and it is NOT hooked up to the ebrake handle. Can someone show me a pic of how this cable attaches or what I can do to get it secured. Thanks a bunch for the help.
702Badge is offline   Reply With Quote
Old 12-20-2012, 03:20 PM   #12
luvbowties
luvbowties's Avatar
Thumbs up Re: Parking Brake Connection
After seeing how it is made, you can tell it really multiplies the force you exert on e-brake handle, huh? If I were to make one, I think I'd drill several holes to maybe give me choices of even more pulling force...since thinking about it, I believe I'll just do that to my original!
Sam
luvbowties is offline   Reply With Quote
Old 12-20-2012, 03:32 PM   #13
luvbowties
luvbowties's Avatar
Unhappy Re: Parking Brake Connection
...just found out 1966 and newer did not even have this: see picture.
Sam
Old 12-20-2012, 03:35 PM   #14
luvbowties
luvbowties's Avatar
Hope this helps.
Sam
Old 12-20-2012, 06:32 PM   #15
702Badge
Thanks Sam!
I can see there is a bolt that appears to go through the u-clamp on the cable, which will go around the ebrake handle. I can't figure out how the cable itself mounts to the ebrake handle frame/etc. From the pic above, it looks like a bolt, but my cable end is straight, no tabs mounting hardware. Is there some speacial clamp that goes aroudn the cable with a hole in it to tightend down? Can you take a pic of the one in your truck?
Old 12-20-2012, 08:34 PM   #16
702Badge
Woo,
Do you have any photos of your ebrake handle and the way the cable attaches?
Thanks,
Thread Tools
Display Modes
