05-12-2003, 10:29 PM | #1 |
what would Neal do?
brake swap from 1981 G20 van to '68 C10?
Hey all, I don't know jack about vans so bare in with me here.
My automotive tech teacher says I can get parts off a junked 1981 G20 van for free. at least I think it's a G20. I know it's a "20"... But I'm not sure if they used the "G" prefix that late...? Well anyway, will these discs be swappable to my '68 910? (a Canadian version of a GMC C10 for those who don't know) I noticed the master cylinder is a good bit bigger on the G20 if that matters... should I and can I swap that along with it ya think? What about the rear? I didn't check if it has discs or drums in the back but I did notice that it looks like a 10 bolt back there... I didn't count the diff. bolts, I just glanced at the back end from afar... I'll investigate further tomorrow... anyway, can I use anything off the back to make my 12 bolt a 5 lug? probably a pretty dumb question seeing how the brakes and axle shafts and everything's a good bit bigger on the 12 bolt, but it doesn't hurt to ask, right? There's nothing left of the engine or tranny, (unfortunately) the stickers say it was only a 5 liter/TH350 anyway so it doesn't really matter because I plan on getting at least a 350 and 4 speed anyway. It looks to have had power steering but I don't think I'll be taking any of that with me seeing how it's somewhat damaged and I plan on buying a 1969 C10 with PS for parts anyway. Thanks for any help. It's all really appreciated. It sure is gonna be fun sneaking those parts on the school bus in a duffle bag. :p
1968 GMC 910 Long Step 250/3onTree 1969 Chevy C10 longfleet, 350/350 |
05-13-2003, 12:36 AM | #2 |
The van front stuff should work, I have a 82 G20 van (heavy half) with 5on5 and I believe the only differnce is some came with rotors that were 1.25" instead of 1.0"thick. from what i can remember the ball joints and tierods are the same as a 71-72 c10. you might (should) be able to switch upper and lower controll arms, spindles/rotors from the van straight over to the truck for your discs. the rear in the van is a 12bolt (mine is)but its wider than than your 68 rear so you cant use the axles.
http://www.earlyclassic.com/ sells axles that will fit into your 68 rear (drums too)and give you the 5 on5" that you want.
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
05-13-2003, 05:31 PM | #3 |
what would Neal do?
thanks. that pretty well answers all my questions.
now I'm wondering if I can put the van's gas tank in my truck..?
Thread Tools | |
Display Modes | |
