Old 05-19-2012, 12:49 PM   #1
RED1985
RED1985's Avatar
Fuel Pressure
OK guys I need a little help. I installed a fuel pressure gauge a month ago and I notice that whne it start up, even after it warm the fuel pressure is right at 5psi. After the run for 15 minutes or more the fuel pressure starts to drop very slowly. It drops all the way down to 2psi after 30-45 minutes. If I rev the engine the fuel pressure never reach back to 3psi, it might only increase .5 psi at most.
New fuel pump and all rubber fuel line replaced. I checked the length of the whole truck for any leaks and nothing.
Any help would be greatly appreciate.
1985 C10 350/700R4
RED1985 is offline   Reply With Quote
Old 05-22-2012, 07:00 PM   #2
RED1985
RED1985's Avatar
Re: Fuel Pressure
Anybody?
Anyone know of a website I might find any answer at? I tried a fuel speciality place but nothing was found after searching.
Thanks,
Edgar
Red 1985 C10 Stepside 350/700R4
2014 GMC Sierra Denali 6.2
2015 GMC Sierra 5.3
Old 05-22-2012, 09:10 PM   #3
bowtiemanchevyman
bowtiemanchevyman's Avatar
Re: Fuel Pressure
check your cam lobe where the push rod runs on and the push rod. they might be worn out. when the motor warms up the oil thins out and the the space between the rod and the pump or the cam incresses and u loss pressure.
bowtiemanchevyman is offline   Reply With Quote
Old 05-22-2012, 09:49 PM   #4
RED1985
RED1985's Avatar
Re: Fuel Pressure
Thanks, I'll pull the fuel pump and check it out.
Thanks,
Edgar
2015 GMC Sierra 5.3
Old 05-23-2012, 10:30 AM   #5
hatzie
Moderator
hatzie's Avatar
Re: Fuel Pressure
Check it with a new US made fuel pump.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 05-23-2012, 06:23 PM   #6
pwradder
pwradder's Avatar
Re: Fuel Pressure
is there a running problem also or is this just something you see on the gauge? if it is also a running problem, check for an in-line filter before the pump that may need replacement. good luck.
pwradder is offline   Reply With Quote
Thread Tools
Display Modes
