Old 05-19-2012, 10:08 PM   #1
crewcabshorty
crewcabshorty's Avatar
buckets into ccsb
i have a 1988 ccsb that i would like to put a set of buckets out of a blazer into . the brackets are not even close to fitting , i could modify them but what brackets could i use to bolt them in ?
crewcabshorty is offline   Reply With Quote
Old 05-20-2012, 12:20 AM   #2
ozark
Re: buckets into ccsb
I used suburban buckets in my crew cab. Had to use the front brackets that were spot welded to the floor from the suburban in the frond and drill a hole for the back bolts.
ozark is offline   Reply With Quote
Old 05-20-2012, 09:21 PM   #3
crewcabshorty
do you happen to have another set of brackets
Old 05-20-2012, 09:56 PM   #4
RandyP
Getting Old; Going Broke
RandyP's Avatar
You'll need the seat tracks and the brackets, or make your own brackets which is what I'd suggest. There are some diagrams floating around on the forum of the shape and size they need to be. Your K5 seat tracks though are going to be way off though.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 05-22-2012, 05:27 AM   #5
texassquarebodies
Truck Nut
texassquarebodies's Avatar
Blazer floor pans are totally different. Suburbans and trucks are the same in that area. Just find you an old burb with them and cutem out. Easiest way.
Tony Kee
Texas Square Bodies
texassquarebodies is offline   Reply With Quote
Old 05-22-2012, 09:24 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
I went from 89 Sub to 78 Jimmy
had to drill my own holes in the seats
bracket for burb floor
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Thread Tools
Display Modes
