Old 05-20-2012, 08:25 PM   #1
Keith Seymore
Keith Seymore's Avatar
House Plumbing - water leak
Gentlemen -
I'm on about my 4th or 5th iteration trying to fix this plumbing leak.
The situation is related to an outside hose bib; there's a section of black flexible pipe, which transitions to a white plastic push in fitting, then to the copper.
It's leaking right at the black pipe/push in fitting. First thing I noticed was the old hose clamp was rusty and nasty, so I cut it off and replaced it with a new clamp and torqued it down. No good.
Next up - let's try TWO hose clamps, right? No good.
So - somewhere in there I decided to try the copper colored permatex RTV and let it set up overnight (24 hours) - still no good.
What's the professional way to fix this? Do I need heat to soften up the black plastic?
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-20-2012, 08:32 PM   #2
thelonerife
thelonerife's Avatar
Re: House Plumbing - water leak
Can you try to cut of some of the end of the black pipe and re-install everything to it? Maybe its cracked on the bottom side, out of sight.
I hate plumbing.
thelonerife is offline   Reply With Quote
Old 05-20-2012, 11:00 PM   #3
yousesteers
Disclaimer first I am no professional plumber just grew up poor in the hog business and messed with lots of that black pipe.
Your best bet is if you have enough black pipe cut off an inch or two and heat it then 2 hose clamps also if you can put a brass barb fitting in instead of the white plastic I usually got along better. Seems after time the plastic ones crack and the fitting will leak over time.
Clint Youse
Paris, MO
1984 Chevrolet 3+3 K30 with Cummins
1966 IH Scout has been a work in progress for 16 yrs
yousesteers is offline   Reply With Quote
Old 05-20-2012, 11:22 PM   #4
67swb72klb
67swb72klb's Avatar
like above said u should have a barbed fitting/adapter for the black tubing try the sprinkler area
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 05-21-2012, 09:06 PM   #5
northern 85
northern 85's Avatar
Yep brass.
northern 85 is offline   Reply With Quote
Old 05-21-2012, 09:09 PM   #6
74 shortbed 406
Definately brass, plastic doesn't dig i.to the plastic pipe and always end up being the culprit. Look at shark bite fittings also, i do not know if they are intended for underground use though.
1978 GMC K25
2002 Dodge Dakota R/T rc swb
In need of some more goodies.
74 shortbed 406 is offline   Reply With Quote
Old 05-22-2012, 09:10 AM   #7
Keith Seymore
Looks like we have a concensus. Brass it is.
Thanks, guys!
K
1979-1986
1986 - 2019
Old 05-23-2012, 12:36 PM   #8
entourageguy
Yellow truck club
entourageguy's Avatar
Yes cut it back if you can add a brass fitting and a bit of heat before using 2 clamps.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 05-24-2012, 07:30 AM   #9
Keith Seymore
Got 'er done.
Thanks, guys - now I can move on to the other 899 things on my "honeydo" list...
K
1979-1986
1986 - 2019
Thread Tools
Display Modes
