White Wall Paint?
Has anyone ever used white wall paint to create your own white walls? I don't want to buy white wall tires this year because Im getting new rims and tires next year. For now I wanted to mess around with creating my own white wall rat rod look, if anyone knows of some paint thay've used or if you have pics of your own painted walls then please sent them my way!!
Thanks to all that look! |
Re: White Wall Paint?
I would go with Portawalls. You could probably sell them when you get your new wheels.
![]() Join Date: Oct 2006
I read on a motorcycle fourm that you can use Plasti-dip aerosol white< you need to scuff the area you want to paint with sand paper tape off and spray away. HIS results came out well . Give it a try and let us know
There is /was aguy on ebay who was selling "white-wall" paint too
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
#5 | |
Thanks |
#6 | |
http://forums.delphiforums.com/n/mb/...9-7&msg=760.34 |
I used duplicolor plastic rubber spray paint a couple times worked great on a set of bias plys, turned out like dog doo-doo on a set of radials.......on my latest truck I wanted the whitewall look with out paying wide whitewall prices and had some white letter tires shaved way better then painting your tires and pretty cheap too not as cheap as paint but still cheaper then real www's..
heres a google search with every possible answer to that question: https://www.google.com/#hl=en&sugexp...w=1280&bih=638
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
There are some good videos of grinding your own whitewalls with a flapper disk. I tried it on an old spare and came out pretty nice.
meowMEOWmeowMEOW
x2 if you have white letter tires try the sanding/grinding method. The results are decent.
Painting whitewalls is ghetto, and probably won't look good as soon as your 100ft down the road.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
all the gring outs i seen didnt go all the way to the rim like bought wide white. i have seen white roof sealer used looked good driving by!
96 s10 static drop smooth and blue 99 silverado nothing stock layed out on 24s 65 c10 bagged patina driver http://www.myrideisme.com/Garage/az480 half-assed build thread http://67-72chevytrucks.com/vboard/s...=1#post5206828 |
here are my white wall painted tires that i just finished a couple weeks ago. I just tried it out as a temporary solution while I save up for the real ones. I grinded out the front 205/70R15s then painted and just cleaned and painted the rear 275/R15s with some tire paint that I got from ebay. The front tires look really nice still, but the rear turned brown after a couple of days. I'm gonna try and grind the rears and paint 'em like the front ones and see what happens. At least 'til I buy the real set.
#12 | |
#13 |
my grinded down whitewalls but honestly if you gonna grind them take it slow cause if you rush your tires will only look good from a couple feet away but when you stand rite in front they look kinda crappy
"So she said, "Either I go or the truck goes!"....Hmm, I wonder what she's doing these days?" |
#14 |
here's my hhr whit grinding the blk wall than painting the white and a few pics of grinding white letters in to whitewalls those last forever the paint last about 30 day's i had a pro do mine whit the best paint u can buy the last pic is a 2012 ram 1500 i had him grind the white letter's in to whitewalls and grind the black for a red wall the red last's along time i have him redo it every 90 day's
Stan's short bed fleet ![]() 69 custom deluxe swb 69 custom swb shop truck 70 custom sport truck swb 72 GMC super custom swb 72 Custom/10 swb inline 6 auto p/s p/b 77 silverado swb 86 Buick Grand National 92 silverado sport swb 06 silverado crew cab 07 caddy sts 08 f250 4x4 crew cab Sold!!! 12 dodge ram 1500 big horn |
#15 |
here's a pic of the whole truck if you look at my pics i have whitewalls on every truck i own im just crazy like that
#16 |
they look pretty straight... what kind of grinder disc did he use?..... also how did you get the red line on there?
Thread Tools | |
Display Modes | |
