Old 05-13-2003, 03:16 PM   #1
jewels.
jewels.'s Avatar
Some questions about 3-on-the-tree column shifters
Hi guys! I enjoyed the discussion so much with my last post today, that I decided to post another thread!
btw,
YOU GUYS ARE GREAT!
THIS IS THE GREATEST BOARD OUT THERE BY FAR!!!
CHEERS!!!!
I have a three speed tranny with a shifter on the column.
When I rebuilt my engine, the mechanic who was showing me how to put all the pieces back together told me that he was somewhat unfamiliar with the column shifting linkage. But, we managed to get it together and functioning.
The linkage that I have is rather loose, and the mechanic mentioned that there might be some spacers of some type that could be put in certain locations to 'tighten things up'. I think he was indicating spacers that might be put near the linkage connections on the tranny.
Has anyone ever heard of this?
Was he just talking out of his ass? (He does this sometimes.)
What have you guys done to 'shore up' or 'tighten up' the three speed column shifters?
Any suggestions?
Thanks again!
jewels
68 C10 Red Step 350 my first child & main focus
58 3200 Apache LWB Step the upcoming project
jewels. is offline   Reply With Quote
Old 05-13-2003, 03:25 PM   #2
Rod
The shifter slop is more than likely up in the column connection. There are small bushings that go into the holes where those 2 arms (in the case of a three speed) clamping type bolts go. Check if the slop is up higher. I havent been under a three speed in a while maybe there are similar bushing set ups at the bottom also.
So pretty much check the bolts and their bushing where parts are connected... you could be missing the bushing all together.
Rod
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 05-13-2003, 03:28 PM   #3
jewels.
jewels.'s Avatar
hmmm - as an afterthought --- this may be a post that could use some pictures ---
i'll try after work this afternoon to post some digital pics to help this discussion
jewels
Old 05-13-2003, 11:38 PM   #4
gr8scott51
gr8scott51's Avatar
The column shifter in mine wore out IN THE COLUMN. I had the option of rebuilding the column - parts are available - or move the shifter to the floor. The Hurst Indy shifter is made for this purpose. But you said you were kinda nostalgic about the column shift, so visit some of the business links and find the parts to rebuild your column. Good luck, Scott
If you decide you want a floor shifter, I have one.
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 05-14-2003, 02:14 AM   #5
yellowgmc
Getting cabin fever?!?!?!
yellowgmc's Avatar
i have on indy to put in. mine jammed in 3rd and i've had no time to fix it yet. soon i hope.
Member of the Discs Up Front Club
1972 GMC 1500
1994 F-150 XL 4x4
Tact is for people not whitty enough to be sarcastic
yellowgmc is offline   Reply With Quote
Old 05-14-2003, 03:41 AM   #6
73stepside
73stepside's Avatar
the spacers go in the flate plates where the rods are in the column. they are rubber. you will have to put washers on either side of the rod to hold the rod tight to the flat plate. on the tranny side, the rods go into a similar thing as the column but no bushings, but tighten with nuts and bolts. once you get to looking at it you will know what i'm talking about.
yellowgmc, to unjam your linkage, there is asepserator inbetween the flat plates coming out of the column. if you wiggle the plates or push/pull on the seperator you will unjamm your linkage. the 73 i use to have did this all the time until i put in the floor shift. just be sure you spend the time to adjust the shifter linkage when you install the floor shifter, of you will have the same problem. i didn't spend the time to do it right and had to tear it down and readjust. spent many hours underneath that truck playing with shifter linkage. also your shift pattern will be backwards from the shift pattern on the knob. there is no other way to install it. they built these for ferds and didn't bother to change them for chevy
04 GMC Sierra RCSS
70 CST LWB
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
Old 05-14-2003, 10:35 AM   #7
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
If you find slack in the colomn is causing it to hang up,(two arms on colunm) there are two bolts on the end right after the two shifting arm, loosen them and they spiral on the colunm which tighten the cluster of arms and bushings.
sneakysnake is offline   Reply With Quote
Thread Tools
Display Modes
