Old 05-13-2003, 03:25 PM   #1
Alexis
Member since 2000
Alexis's Avatar
Exclamation differance between front brake line 70-71???
What are the differances between the line from 70-71? pictures would be great.
Alexis is offline   Reply With Quote
Old 05-13-2003, 03:28 PM   #2
case_bt
case_bt's Avatar
on the 70 the lines run on the back of the crossmember and on the 71 they run along the front
case_bt is offline   Reply With Quote
Old 05-13-2003, 03:54 PM   #3
Alexis
Member since 2000
Alexis's Avatar
I must be getting to early classic............well the line they sent me were wrong. We fixed the situation and they decided to to send me the ones I needed in the first place.
Old 05-13-2003, 04:02 PM   #4
Alexis
Member since 2000
Alexis's Avatar
thanks for the help. The info you provided me help me out greatly.
Old 05-13-2003, 04:10 PM   #5
67cst
i love summertime
67cst's Avatar
lol, alex i know what you are going through, i got a 71 frame and when i put the booster and master cylinder on it i went to connect the 2 brake lines to the proportioning valve, turns out the fittings on the ends of the lines are different sizes, that was a piss off forsure, i think 72 they had a bigger fitting that 71
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 05-13-2003, 04:35 PM   #6
Alexis
Member since 2000
Alexis's Avatar
fitting sizes. I totally understand that.......Big red had a field day on me lookin for fitting for the rear lines. That was a whore. What suck though is the fitting I needed were at the local kragen.
Thread Tools
Display Modes
