Is the heat on?
Now that it's getting warmer I'm noticing the inside of my truck is getting hot when I have the windows closed. (at night) The heat is turned off and set to cold, but I still feel like it's on a little bit. I know the blower fan always blows even in the "off" position, is that making the heat? I'm not quite sure if it's coming from the HVAC or just through the firewall.
Anyway, does it sound like maybe my heat controls aren't turning off all the way? I'm wondering if maybe I should install a valve to shut off the heater core for the summer....
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's. You can set my truck on fire and roll it down a hill, and I still wouldn't trade it for a Coupe de Ville. |
Re: Is the heat on?
My blower does not run in the off position.
"Whoever said money can't buy happiness has obviously never seen a speed shop! |
Re: Is the heat on?
in the 60's people died from lack of oxygen with windows up.
chevy fixed this by constantly running the fan to pump in fresh oxygen. turn your controls to cool to avoid drawing air from the heater core, other than that u can just disconnect the blower in summer but i wouldent recommend it due to.......uggh....dying. ![]() also chevy made the fan run to keep the heater core cool to get more life out of it, however here in the valley when its 110f out side, its killer... my non ac truck always has the windows down so im used to it..... i suggest u just leave it alone. |
Re: Is the heat on?
#5 | |
Re: Is the heat on?
Re: Is the heat on?
my 77 did run all the time but i put a cheap on/off switch under the stering column and cut the power wire for the bower motor and ran it through the switch works like a champ
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin 79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s 81 mercedes 300d 25 MPG 77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded" 73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091 '77 chevy trucks. built to stay tough. life is short build a hot rod ![]() |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Is the heat on?
the only time the fan motor blows is when the ignition switch is on the on position
some vehicles had low as the lowest setting others had off if you have off the blower motor should be not turning
Re: Is the heat on?
Theres always coolant running through that heater core so some heat will always make it in especially with the fan always running. Ive seen people run a bypass or plumb in valves for the warm months.
Re: Is the heat on?
Most big trucks like mine (Peterbilt) have heater core shut off valves to cut off coolant to the heater core for summer months, this is an option you could try to remove excess heat from your cab. In all likely hood I would bet its you blender door not sealing good or operating properly.
John 82 Chevy Silverado 350ci/TH350 ![]() |
Re: Is the heat on?
Could be junk and leaves blocking your "core bypass door" which is what I call it. Your levers have a cable or stiff wire that actuates this flapper door that switches from outside air to heat. It can get blocked with junk and not close or it can rust and have a hole in it.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#11 | |
Re: Is the heat on?
![]() All of mine have done this, one of the little "penalties" of owning an older truck.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ![]() I'm kinda like duct tape- no real purpose, but handy to have around. |
Re: Is the heat on?
My 79, 81, and current 84 the blower did not run roll the windows down if it gets hot or open the lower vents on each side
Clint Youse Paris, MO 1984 Chevrolet 3+3 K30 with Cummins 1966 IH Scout has been a work in progress for 16 yrs |
#13 |
Re: Is the heat on?
Here is what I use on my 5/8" heater hose. Picked it up at the local auto parts store several years ago for less than 10 bucks. Turned off in the spring and back on during the winter months. Makes a world of a difference during our hot Oklahoma summers.
Joe __________________________________________ 1975 C10 "Questions are a sign of intelligence indicating a desire to eliminate ignorance" |
#14 |
Re: Is the heat on?
Thanks for the replies everyone...I think I have a 3/4" ball valve out in the garage, I'll try and plumb that into the heater core.
#15 | |
78K & 79C Jimmys
Re: Is the heat on?
but caught in traffic i like to put the heat on,if i see it climbing and no air flow threw the rad just cut the low speed wire on the fan 78 has three speed fan,79 has 4 speed both mine now have off
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#16 |
Re: Is the heat on?
I used to have a Jeep like that...year round heat to keep the engine cool.
#17 |
78K & 79C Jimmys
Re: Is the heat on?
han't seen mine over half but thats what i do sitting in traffic
Did you know in the air box there is 3 ajustment holes for the def/floor air flow 66% def or floor with 33% always the other way or 100% up or down that would mean if the fan is always on ,it's always flowing threw it and looking on lmc i can't find a pic....
Thread Tools | |
Display Modes | |
