Old 05-29-2012, 11:10 PM   #1
48 GMC BURB
48 GMC BURB's Avatar
Question NEED Cross member help
Anyone know who makes a replacement/tube A arms... front cross member for a 74 -2wd Blazer...same as a C 10 short box I think.the one I have is rusted through at the spring perch..Looking for suggestion's
TKC
KC
48 GMC Burb
51 Chevy AD 3100/C 4 byShannon
74 Chevy P 10
48 Double Duty
04 SS Burb
01 Springer HD
48 GMC BURB is offline   Reply With Quote
Old 05-30-2012, 12:40 AM   #2
Pro Performance
Pro Performance's Avatar
Re: NEED Cross member help
I would definitely recommend a Porterbuilt crossmember. If you are planning on swapping it out, and want to go aftermarket, then that is the way to go.
You don't necessarily have to run air bags either, as they have a spring adapter so that you can utilize your coil spring. Not only does it offer you more ground clearance, it also have better geometry and a rack/pinion steering setup.
You can check out the details here, and feel free to give us a call with further questions.
Porterbuilt Dropmember
Pro Performance is offline   Reply With Quote
Old 05-30-2012, 07:12 AM   #3
andrewmp6
Nate is working a mid dropmember http://www.porterbuiltfabrication.co...il-Over-Option
andrewmp6 is offline   Reply With Quote
Thread Tools
Display Modes
