Old 06-10-2012, 03:32 PM   #1
mknittle
mknittle's Avatar
guys that replaced the floor with sheet metal
How did you do the front cabmounts? could you post some pictures?
Thanks Mark
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 06-10-2012, 04:39 PM   #2
Kim57
Kim57's Avatar
Re: guys that replaced the floor with sheet metal
Here's what I did.
I used 16 gauge sheet and cut it to fit like the original.
I cut the original large washers out and drilled a large enough hole so they would recess like they did in the old floor.
Put the new floor in position and then bolted the washers in.
Made sure everything fit and then tacked it all in.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 06-10-2012, 05:22 PM   #3
Indian113
Indian113's Avatar
Great Job-Very good explanation and pictures. Stuff like that sure makes this site great.
Indian113 is offline   Reply With Quote
Old 06-10-2012, 07:50 PM   #4
mknittle
mknittle's Avatar
yes Indian I agree! it really is nice to be able to see how other people do things before getting started.
Mark
My GMC build.
Old 06-10-2012, 10:28 PM   #5
Kim57
Kim57's Avatar
Thanks guys.
Kim
My build thread
Old 06-15-2012, 12:34 PM   #6
WONKA1955
looks great kim, can you post a front view on the firewall.
WONKA1955 is offline   Reply With Quote
Old 06-15-2012, 12:41 PM   #7
Kim57
Kim57's Avatar
Here's a couple.
One before and one after I made the cut out for my engine.
Kim
My build thread
Old 06-15-2012, 01:00 PM   #8
Rude Dude
Rude Dude's Avatar
Here is a link to a how too
http://www.thehollisterroadcompany.c..._Firewall.html
Rude Dude is offline   Reply With Quote
Old 06-15-2012, 01:04 PM   #9
WONKA1955
great link. Thanks Rude Dude.
Old 06-15-2012, 08:55 PM   #10
mknittle
mknittle's Avatar
I like the way Kim did the in set panel.
Mark
My GMC build.
Old 06-16-2012, 08:15 AM   #11
n_elsod
n_elsod's Avatar
I bought the kit from classic parts for the front with trans hump.
n_elsod is offline   Reply With Quote
Old 06-16-2012, 10:04 PM   #12
mknittle
mknittle's Avatar
Looks good. That's a neat truck you have built!
Mark
My GMC build.
Old 06-18-2012, 11:28 AM   #13
nacho55
My floor was rusty but the cab mounts were still solid so i just trimed out the old metal untill i hit solid steel again, I used cold rolled steel scraps from my local supplier, its easier to weld with since you dont have to to remove all the mill scale, and the way i swaped in the front clip i raised it up so i wouldnt have to use lowering springs, but ended up having to build a tunnel for the trans, only thing i had bent was the floor part at my buddies house who had a brake, but any metal shop will bend yours up for a couple bucks or i have had luck with my local muffler shop bartering with beer for scrap pieces or getting a quick piece of pipe bent up, heres a couple pics of what i did, also bent the tunnel by hand beating it into shape with a combination of tools including a dead blow hammer, a welding bottle and roughing out the large part on a actual sand bag, i started with some posterboard template and just kept trimming till I had the parts the way i wanted.
nacho55 is offline   Reply With Quote
Old 06-18-2012, 06:49 PM   #14
mknittle
mknittle's Avatar
Thanks nacho55 that looks great!
Mark
My GMC build.
Old 06-18-2012, 07:05 PM   #15
mknittle
mknittle's Avatar
I dont know about my cab mounts yet.The floor, toe board and lower kick panel on the passanger side are pretty holey. so I am thinking that I will need to make new ones. The plan now is to make a framework out of 1''X1" tubing then cover it with 18 guage sence I already have more than a sheet and about 30' of the tubing.
I have been doing some simple hammer forming with some pretty good results.So we will see where that goes. I like the welding bottle idea too.
Mark
My GMC build.
Old 06-18-2012, 11:00 PM   #16
nacho55
I too did some bracing under the floor with some 1"x3" tubing, (because that's what I had) and it turned out pretty solid, Another thing I did that saved some time fitting was placing the tunnel on the floor and centering it till it looked good and then cut out the overlapping parts from underneath and grinding it smooth. (hope that makes sense)
Thread Tools
Display Modes
