Old 06-10-2012, 10:44 PM   #1
Oldgearz
Oldgearz's Avatar
sheared bolt question
I'm putting in Chevelle springs in the rear, hopefully will be enough drop, but of course I have to get the stockers out first. Apparently they hadn't been touched since '62 and I sheared both bottom bolts for the perches. I used liquid wrench and wd40 both and let them sit before I had attempted moving them with a torque wrench and I was trying to go easy. Didn't work. Should I drill them out or do I need to try something else? I would need to drill them from the underside. Another question I have is depending on how much Chevelle springs will drop the rear, do I need to get the adjustable trac bar or will I be ok?
1962 GMC 1/2 ton stepside longbed, 305 V6, Muncie 3spd HD tranny, stock rear end, rolling resto!
Oldgearz is offline   Reply With Quote
Old 06-10-2012, 10:54 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: sheared bolt question
Is your bed off and can you get a four inch grinder in the rails to grind the head off, yes you`ll need a adjustable panhard bar and shock relocators.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 06-10-2012, 11:23 PM   #3
Oldgearz
Oldgearz's Avatar
The coils are stuck in place for now, can't get inside the coils to the threads. I even tried vise grips, no grip. About the shock relocators.....why the need? I do have shorter Gabriel gas shocks for it.....about 3 inches shorter than what I had. I figured it should work fine in the stock location?
Old 06-11-2012, 07:31 AM   #4
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
a trick for sheared bolts.
get a washer that has a center hole a tiny bit smaller than the bolt.
weld the center of the washer to the sheared bolt.
now weld a nut or bolt to the washer, and use a wrench to unscrew it.
the heat from the welding should free up the stuck bolt. another thing you can do is when it is still cherry red, spray some water on it, the sudden cooling of the bolt will cause it to contract, and should help break it loose.
Old 06-11-2012, 08:05 AM   #5
theastronaut
theastronaut's Avatar
This works great, used the techinique on some allen head bolts on Jeep hinges that were rounded out. Start the weld on the bolt head and let it burn in to the bolt good for a couple seconds before moving the tip around and welding on the washer. That'll help the weld to be strong enough to hold, and get more heat on the bolt to help loosen it.
theastronaut is offline   Reply With Quote
Thread Tools
Display Modes
