Old 06-11-2012, 10:21 AM   #1
hardhead
Gas tank install
I just thought you guys might be interested since there has been so much discussion on under bed tanks. I just bought an aluminum tank from Northern Tool and installed in my sons 66. It holds 16 gallons and its a perfect fit between the frame rails. The filler looks like it hits the center of one of the boards so I will fill it from inside the bed. I believe the only mod will be to cut one of the cross sills. I think I am going to cut it out and weld in a piece of 4" tubing so when you open the filler you reach in the pipe to open the cap. I think the tank was $210. I will try to post somw pics when I get time.
hardhead is offline   Reply With Quote
Old 06-11-2012, 10:28 AM   #2
1963c-10
1963c-10's Avatar
Re: Gas tank install
Theres a ton of threads here on under bed tanks. Use the search engine under 67-72 chevy at the top of the page.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-11-2012, 10:31 AM   #3
hardhead
I have already installed a tank, just trying to give some information for others who might want to try the same tank I used.
Thread Tools
Display Modes
