Old 06-13-2012, 04:07 PM   #1
MidLifer
MidLifer's Avatar
350 engine for rebuild
It is what it is (a rebuildable 2-bolt core) and the block seems to be originally from a car, not a truck, but I'm pretty sure the heads and manifold are the originals from the truck and I have production date codes so if you are going for a numbers-matching project on a 71, these may be of interest.
The short block or the entire engine is available for local pickup, but I would ship the heads or the intake manifold. Asking $200 for the whole package, $100 for the pair of heads, and $30 for the manifold. Shipping depends on zip code - the manifold would most likely fit in a flat-rate box. Exhaust manifolds are both cracked.
Details:
Block is a 2-bolt, #3956618, "H0205HV" casting code but no VIN#, Production date C229
Heads are #3973487, production date A111
Manifold is #3973469, production date A91
#6 piston skirt is cracked off. The engine ran until I pulled it 2 weeks ago, but both main seals leaked and it was running rough. It did not burn oil and the compression was good (130-150 across the board). I haven't torn it down but I've had the oil pan off and the lower end looks good.
MidLifer is offline   Reply With Quote
Thread Tools
Display Modes
