Old 06-14-2012, 01:15 AM   #1
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Hydroboost setup in '66 w/LS motor
I'm currently running manual brakes, disc up front (wilwood d52) and drums out back. I have an lq4 w/the hydroboost ps pump....so what do I need to get, and do to set it up?
I imagine I'll need the hydroboost unit, and a new master cylinder? OR does my MC mount to the hydroboost unit?
I'll probably need to get a mounting bracket from captainfab as well.
Does it matter which year parts I get, or do I have to use later model stuff because of the newer model ps pump?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-14-2012, 10:43 AM   #2
OneOffStroker
Re: Hydroboost setup in '66 w/LS motor
http://www.67-72chevytrucks.com/vboa...d.php?t=523502
A thread I made up a couple months back. It's not a '66, but I can't imagine it would be much different. You're a crafty guy, so it shouldn't be too much of a headscratcher for you.
Good luck!
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292
1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987
Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker
OneOffStroker is offline   Reply With Quote
Old 06-14-2012, 12:50 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Ahhhh, ok...so that thread helps a bit.
This one i think shows me what I wanted to see. Its PS Pressure -> Boost IN -> Boost Pressure ->Steering In -> Steering Return -> Pump return ?
Whats with the capped return on the HB unit?
Old 06-14-2012, 01:26 PM   #4
OneOffStroker
Yeah, you got it. I didn't have the install complete when I took those pics and posted the thread, so I guess it could be a little confusing. The capped return is indeed a low pressure return, and should not be capped. It gets T'd into the steering gear return, or more accurately, the steering gets T'd into it on its way back to the pump.
Some pics I just snapped today for you:
Old 06-14-2012, 02:26 PM   #5
Custom 68
Custom 68's Avatar
did you do any modifications to the brake pedal? Or is it hooked up like Stock?
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 06-14-2012, 03:36 PM   #6
BLK2K2SILVY
BLK2K2SILVY's Avatar
Ive got a hb unit and ps pump off a 06 2500 to swap into my 1500, but I may just swap it into the c10.
BLK2K2SILVY is offline   Reply With Quote
Old 06-25-2012, 06:25 PM   #7
OneOffStroker
I didn't modify the brake pedal itself any, but I did a little work to the bracket itself, since I smoothed the firewall. I basically sectioned about 1.5" from the front of the bracket, because that's about how far back I moved the firewall when I smoothed it. CLick the link in post #2 for some shots of the clevis attachment to the pedal.
Here is a shot of the sectioned brake bracket:
Thread Tools
Display Modes
