Old 06-14-2012, 06:01 PM   #1
66_c10_tpi
Play in door hinges.
I reinstalled one of my doors back on the cab that I am rebuilding. How much play should I have before I need to rebuild the hinges? The hinges feel tight off of the truck. But I can pry up the door at the B pillar about a 1/4" is this normal?
Thanks for your help.
66_c10_tpi is offline   Reply With Quote
Old 06-15-2012, 08:16 AM   #2
awbrown
Re: Play in door hinges.
I replaced all the pins and bushings in mine , it is not too bad of a job....
awbrown is offline   Reply With Quote
Old 06-15-2012, 09:06 AM   #3
Rich 5150 69
Rich 5150 69's Avatar
It`s much easier to do this wth the doors on and the fenders off.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 06-15-2012, 02:41 PM   #4
66_c10_tpi
Where did you purchase the pins and bushings?
Old 06-15-2012, 10:12 PM   #5
awbrown
http://www.classicparts.com/1960-91-...ctinfo/18-406/ I had the hinges off when I did it ,sometimes you have to persuade the pins to move...........
Old 06-15-2012, 10:18 PM   #6
padresag
you can more than likely get them at your local auto parts store. they are of a std size bushings and pins. I can get them at my local jobbers
ron
padresag is offline   Reply With Quote
Old 06-16-2012, 07:12 PM   #7
66_c10_tpi
ron
Thanks I will give them a try.
Old 11-21-2014, 10:45 AM   #8
Grizz1963
Grizz1963's Avatar
Thread resurrection....
When I open my passenger door, it seems to drop a bit from the latch.
I guess that means there is wear somewhere in the hinges.
Does that sound right, or do I have a different problem to worry about??
Thanks. Rian.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 11-21-2014, 10:56 AM   #9
Improbcat
Improbcat's Avatar
Thanks. Rian.
Yep, if you lift up on the back of the door by the latch and it moves up & down the hinges are worn and need new pins & bushings or to be replaced.
1964 C/10 Longbed Fleetside, base model. (build thread) (pictures)
SOLD 1964 C/10 Shortbed Fleetside, Deluxe. (pictures) SOLD
Improbcat is offline   Reply With Quote
Old 11-21-2014, 12:19 PM   #10
Grizz1963
Grizz1963's Avatar
Cool. Thanks.
Wobbly Wobbly is what it is.
Thread Tools
Display Modes
