Old 06-16-2012, 01:36 AM   #1
rockin562
rockin562's Avatar
cab seam question
ok guys im about to fill in my seam on top rear of the cab and i took a wire brush to get all the seam sealer out. my question is way down inside the seam there is still some stuff that actaully looks like all metal filler but not sure. can i weld over this???
rockin562 is offline   Reply With Quote
Old 06-16-2012, 09:29 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: cab seam question
I've done the same with the wire brush thing in the past. I just insured all of the old sealer and rust is removed and then reasealed it but I don't know what this metal filler is though? It could be that another owner used some Metal Set or similar. Never know on these old trucks. I would just remove as much as you can, use some metal condtioner on rusty spots you can't get to and reseal and paint it.
Some prefer to paint with good epoxy or other good quality paint first. Instructions will tell you which is better.
68gmsee is offline   Reply With Quote
Old 06-16-2012, 06:18 PM   #3
rockin562
rockin562's Avatar
My question is is it safe to weld over.
Old 06-17-2012, 12:29 AM   #4
litew8
litew8's Avatar
top/rear of cab. We didn't mess with it on mine, but we thought it could possibly be Lead.
Not way down inside, but the entire seam that runs across the top/back of the cab.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 06-17-2012, 05:39 AM   #5
If you're going to weld the seam,why not put a torch to it and see what happens? I would think it should be out of there for a proper weld. I'd burn it out with a torch if you can't get at it that deep.
Old 06-17-2012, 10:05 AM   #6
hugger6933
I will echo the post above it was what was alreadt thinking before I read down that far . get a torch and heat the seam to see if it is lead. I have had it on my list of things to do but it will be a lot of work[ of course what isn't on these trucks?]
hugger6933 is offline   Reply With Quote
Old 06-17-2012, 02:26 PM   #7
rockin562
rockin562's Avatar
Thanks guys. Torch it is.
Old 06-17-2012, 05:27 PM   #8
litew8
litew8's Avatar
Take care and do not breath in the fumes.
And if you're grinding on it (if it is Lead), take caution to dust.
You don't want to be touching that stuff or transmitting it into your home via clothing.
Thread Tools
Display Modes
