Old 06-17-2012, 09:51 PM   #1
NuttinSpecial
NuttinSpecial's Avatar
Ride quality on 25 series tires?
Im baggin my 68' and cant decide if i want to run (in the rear) 24s on a 25, or 22s on a 30 or 35 tire? Anyone rode in a bagged vehicle on rubberbands? Ive heard its hell on a spring suspension but not so bad on bags? Thanks for any input
NuttinSpecial is offline   Reply With Quote
Old 06-17-2012, 10:03 PM   #2
BMERDOC
BMERDOC's Avatar
Re: Ride quality on 25 series tires?
Low pro and ride quality never go together. Being a long time BMW guy I will get more serious and answer in a more educated manner. If you go down in profile the suspension has to be designed to compensate for the less compliant sidewall. This all goes out the window when you have an adjustable suspension. Which is your case. Like you said "its hell on a spring suspension". When you run that set up you don't have many choices in spring rates or shock/strut valving. Manufacturers can do it in during new vehicle testing. All you have to do is drop a couple more psi to compensate. Watch out for potholes!!
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 06-18-2012, 12:16 AM   #3
NuttinSpecial
Hahaha good advice.
So how many psi are we talkin? For example if you usually would keep it at 32 what would you drop it too?
Old 06-18-2012, 09:30 AM   #4
BMERDOC
BMERDOC's Avatar
Sorry, I meant soften up the bags. Not the tires.
Nick Carter
Old 06-18-2012, 09:59 AM   #5
NuttinSpecial
Ohhhh the way you said watch out for potholes i thought you meant tires lol. I see what your sayin now.
Thread Tools
Display Modes
