06-23-2012, 09:39 AM | #1 |
The Older Generation
Window assembly sequence
I have been searching for information this morning on the assembly of the window behind the drivers door on my '69 Suburban. I don't have a clue on this one since the truck was in a million pieces when I bought it. I can probably figure out the main window but the stationary 1/4 window, two piece upper channel sections, and glass channels I'm not so sure about. What goes in first and what goes in last on the assembly of this unit? Any assistance, tips, or links to threads/posts greatly appreciated. Thanks. LockDoc
06-24-2012, 08:11 AM | #2 |
Re: Window assembly sequence
Wow, 46 views and not even a hint? Come on guys, throw me a bone... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 06-24-2012 at 06:41 PM. |
06-25-2012, 10:14 AM | #3 |
Would it be in the assembly manual maybe? That would be the first place I'd start looking. Then move to the service manual, for the disassemble sequence; the reassemble will be the reverse of that. If that fails, maybe try a Chilton or Haynes manual.
Good luck!
-Nathan- 1972 GMC K2500 Suburban "The Project" 2013 GMC Sierra 1500 SLT Z71 "The Daily Driver" 2005 Ford F150 Lariat SCrew 2WD "The Daily Driver" SOLD 1995 GMC Sierra C1500 SLE "The Daily Driver"SOLD 2003 Ford Ranger Edge 2DSC 2WD Flareside "The Daily Driver/Project"SOLD |
06-25-2012, 12:20 PM | #4 |
Restoration Virgin!
Leon...did you see this thread??...http://67-72chevytrucks.com/vboard/s...d.php?t=462415
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
06-25-2012, 04:07 PM | #5 | |
First place I started looking too. Great reference as far as where the parts go but nothing as far as what order they go together. Same with the service manual. Neither even mentions the 2 piece reveal moldings. Thanks for your input though. LockDoc
06-25-2012, 04:10 PM | #6 | |
I read that one Geoff. Too bad the OP didn't post a followup about what worked for him... Thanks. LockDoc
06-26-2012, 08:11 PM | #7 |
New Member
I just did mine about 6 or so months ago. I actually had the fixed window in first and managed to squeeze the operable glass in without any damage or scratches, but wouldn't do that the next time. This is how I would do it knowing what I know now:
install forward glass run metal bracket (assuming you took it out) install window regulator install operable glass Install fixed window and weatherstrip install division bar (between fixed and operable window) install glass run felt top and side (front) install wipers/scrapers My biggest challenge was the front/side glass run felt. I started installing from the top down with the window all the way down, then you push it in as far as you can go (and run int the glass). Then I rolled the window up and past the point where I had to stop (can be tight, don't break your regulator!) and pushed in the rest of the felt now below the glass. Hope this helps. |
06-26-2012, 11:39 PM | #8 | |
LockDoc
06-28-2012, 11:07 AM | #9 |
Leon,
Don't know if you did it yet or not but I found this in the Assembly Manual section 18-19: Body Side Window Assembly (Roadside) and Front Stationary Window- Suburban (Figs. 54 & 55 Statioary Glass Replacement 1. Wind window to full down position. 2.Remove hand controls and trim panel 3. Remove cats and whiskers and rubber stripping or seal. 4. Remove one upper door attaching screw and two lower securing the window divider run. 5. Pull downward on run and forward. 6. Remove stationary glass with rubber seal attached, and remove run by pulling through a glass opening. 7. Reverse procedure to install.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
06-28-2012, 04:04 PM | #10 | |
Still not installed... Not sure how I missed that, but I did. I was going to try and get it done for the Des Moines, IA GoodGuys this weekend but that isn't going to happen. I have a couple of other vehicles I can take so it isn't a problem anyway. Thanks for your post. LockDoc
Thread Tools | |
Display Modes | |
