06-24-2012, 12:50 AM | #1 |
3/4 ton link Question
I have a 68 k20, and I want to make it a link style suspention with air bags and coil over shocks, for ride, but do you think that this set up can handle a very heavy load, I'm just looking for something to actually make my truck ride good, like it does with a full cord on the back, any way any input would be nice, thanks
Will |
06-24-2012, 11:21 AM | #2 |
Re: 3/4 ton link Question
Air bags would work better for accommodating heavy loads & good ride quality. I can't recall seeing any coil-over shock set-ups intended for heavy loads (beyond those old, cheapish, coil over the shock add on set-ups).
06-24-2012, 10:03 PM | #3 |
Sorry, what I'm really asking is if I can just use air bags as a good ride and also a good ride quality out of it,
06-24-2012, 10:50 PM | #4 |
Yes. Bags can/will offer excellent ride quality & versatility; loaded or not.
06-25-2012, 07:11 AM | #5 |
Being a 4x4 i would try a set of helper bags in the rear.
06-25-2012, 06:28 PM | #6 |
I'm planing on getting rid of the old 3/4 ton springs, (the kind that fell like someone welded the axle to the frame) and going with a 4 link style suspension, and I'm wondering what needs to be there to support everything and give a good ride as well, or will it limit the flex of the truck?
06-26-2012, 01:36 AM | #7 |
If you want flex like off roading i would go with a triangulated 4 link with good coil overs.The front you could do a 3 link with a track bar.Just crawl under any jeep wrangler 97 and newer they run that kinda suspension stock.If your building a on road and off road you can use good adjustable coil overs so its stiffer on road and front and rear sway bars with disconnects or currie makes a antirock sway bar that is more for on road and off road.
06-27-2012, 01:53 AM | #8 |
Take a look around http://www.ballisticfabrication.com/ and http://www.bluetorchfab.com/
Thread Tools | |
Display Modes | |
