Old 06-25-2012, 02:03 PM   #1
youseez
Fuel Filter Issues
I am finishing a 5.3 Litre swap into my 71 stepside and having some trouble with fuel filters clogging. I have a new tank, pump, all new lines, and running the filter/regulator set up from a corvette. when i first fired the engine i had good fuel pressure and the motor ran fine, as time went on (couple of days with various starts while working out bugs) i lost all fuel pressure and could barely get the truck to idle. I replaced the fuel filter and every thing was great, then drove the truck for about 15min. and same thing lost fuel pressure and could barely get it to idle and run.
youseez is offline   Reply With Quote
Old 06-25-2012, 05:24 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: Fuel Filter Issues
Is there a lot of trash in the tank you are using?
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 06-25-2012, 06:03 PM   #3
youseez
I didn't think so, from what I could see it looked clean, and it is brand new. But now who knows, I have to be picking up some junk from somewhere or something is going on with the fuel filter. I orderd a different brand of fuel filter to see if that changes anything.
Old 06-25-2012, 07:56 PM   #4
clinebarger
Have you tried blowing through the filter, I highly doubt a filter would clog that fast.
clinebarger is offline   Reply With Quote
Old 06-26-2012, 02:32 AM   #5
BigDan3131
BigDan3131's Avatar
I would try buying your gas somewhere else, they might have junk in their tanks. When you put this system together did you use any excessive amounts of thread sealant?
BigDan3131 is offline   Reply With Quote
Old 06-27-2012, 09:26 PM   #6
youseez
I replaced the fuel filter again, and filled the tank and it seems to be doing fine. I took the truck out for a good drive last night and everything is good!!!!!
Old 07-21-2012, 11:51 AM   #7
youseez
Have been driving the rtruck for 3weeks now and it is awesome. Took it out last night, and on the way home the same old problem again, no power when revved, but it will idle. Very low to no fuel pressure on the gauge WTF!!! I guess I will throw another fuel filter in it today, this is getting old.
Old 07-23-2012, 12:10 PM   #8
awhite4557
awhite4557's Avatar
Remove the fuel filter and cut it open to see if anything is inside stopping it up. What kind of fuel lines did you use, some rubber hoses will not withstand the high flow of fuel and will come apart from the inside and could stop up the filter. Just a suggestion since your post doesn't state what fuel lines you used. Either way, I would cut the filter open to see if it is actually stopped up and what is inside.
1950 Chevy 3100 Ramp Bed 1-ton
http://67-72chevytrucks.com/vboard/s...d.php?t=749386
1965 Chevy Step Side
1971 Chevy Short Wide Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=277191
1971 Chevy C-30 1-ton
1971 Chevy Chevelle
1972 Chevrolet C-30 1 ton
2005 Dodge Ram 2500 5.9 Cummins
2017 Fleetwood Pace Arrow 35M motorhome 350 Cummins
2020 Jeep Wrangler Unlimited Rubicon
awhite4557 is offline   Reply With Quote
Old 07-23-2012, 12:35 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
did you convert to a car intake or different rail? I see your running the 'vette regulator on a truck setup.
you could try running a screen style pre-filter if it really is stuff geting into your pump and filter, but it shouldn't be a necessity.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-23-2012, 12:41 PM   #10
ls1nova71
ls1nova71's Avatar
I agree cut it open and make sure it is really clogged. I have heard of cheaper filters having bad regulators out of the box. I would get a wix or ac delco if you don't have one of them already.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 07-23-2012, 04:30 PM   #11
OldCreek
OldCreek's Avatar
Are you sure you don't have a vapor lock issue or a vacuum problem that gets relieved when you disconnect the fuel filter?
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 07-25-2012, 01:01 PM   #12
pwtr02ss
I agree with the folks that mentioned trash in the line. I used the braided hose on my truck so you have to cut it with a cut-off wheel. When i blew the line out it was full of the rubber "dust"
pwtr02ss is offline   Reply With Quote
Old 07-25-2012, 03:01 PM   #13
Shon
Filtering before the vette reg/filter?
Is the gas tank vented? or using a vented cap?
Any codes?
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 07-25-2012, 07:48 PM   #14
youseez
Drove the truck all weekend in 105 degree weather with the AC cranked and no overheating or fuel issues, this thing is awesome!!! beside this minor filter issue. I dont know the brand of filter I picked up during the build, I am assuming they were cheaper made because the cost was cheap, i have been thru all 3 of them now. I made sure to put in a AC Delco in this time. The entire fuel system is brand new with steel braided rubber hose Walbro pump, corvette filter/reg and a Boyds Welding Fuel tank. I am running the stock truck intake.
Thread Tools
Display Modes
