06-27-2012, 10:44 AM | #1 |
1967 SWB Project / Part out
Right now the truck is apart. The frame has been painted with the chassis black from Eastwood company. The upper and lower a-arms have new cross shafts and bushings. New ball joints in upper and lower a-arms. New rotors and calipers and brake pads. The truck has 5-lug front and rear. Rearend is a Posi, but unsure of gear ratio. Has CPP lowering kit, 4 rear/2 front, with correct lowering shock. Chassis has not been put back together yet. If wanting just chassis, would like to sell as a rolling chassis, complete with CPP parts
The bed sides have been stripped down to bare metal, and just a light coat of primer. Starting to get minor surface rust on it. The inside of the bed has been epoxy primered. We were going to rhino line it. Bed in real good shape. Has a few dents that will easily pull out. I also have the stake pocket fillers that will go with truck. It didn’t come with a tailgate when we bought it, but I do have one know that goes with truck, it is a stock one, and in pretty good shape. Cab is in pretty good shape. Does need part of the floors replaced, but I have the panels to replace. The guy we bought it from, said that he had a professional replace, rocker panels, cab corners, and cab supports. The rocker panels and cab supports were done. The cab corners another story. They just put sheet metal over the corners then added a lot of bondo to hide it. We started to strip the cab and found out all the bondo was on cab. Doors are in real good shape, other than a crease on the passenger side door. It will pull out. All glass is good, small back glass cab. Also have fuel fill delete plate for cab. Driver side fender and inner fender in good condition. Passenger side fender has some rust in bottom front of fender, under battery tray spot. Inner fender has rust through under battery tray also. Radiator support in good condition. Does not come with front or rear bumpers. Hood in real good shape, didn’t come with hood hinges, but I do have a good set of stock ones that will go with truck. Ok, here is a list of everything that will go with truck if you buy everything: Everything new unless stated: Chrome steering column w/adapter, brake booster for disc front/drum rear w/portioning valve, aluminum gauge insert w/shark gauges, CPP tubular transmission mount, CPP tubular motor mounts, CPP rear pan hard bar, CPP fuel sending unit, CPP in bed fuel fill w/ clamps and hose, 1 piece door window kit(both doors), stainless steel braided transmission dipstick tube, CPP trailing arm u-bolts, box full of new heater parts, used automatic brake pedal and mount, split seats out of 98 chevy truck(has seat belts on seats already) w/center arm rest, used turbo 350 transmission, hood hinges(used) Engine: Everything New. Block is a 400 sbc, bored .030 over, 509 block(very good block) 200cc Aluminum heads, 64 cc w/ steam holes, 2.02/1.60 valves, hardened valve seats, bronze guides, plus .400 thick deck for severe uses, valves are one piece forged stainless steel, springs are good to .500 lift, polished aluminum timing cover, Erson- flat tappet hydraulic lopey cam, aluminum 1.5 ratio 3/8 stud roller rocker arms, ARP intake bolts, matching intake gaskets, new head bolts w/washers, Crosswind dual plane street and strip aluminum intake, complete engine gasket, matching 5/16” .065 wall pushrods, hydraulic flat tappet lifters, cam lock plate, aluminum tall valve covers, aluminum valve cover breathers, noisy gear drive timing set, aluminum water pump, chrome mechanical fuel pump, oil pump kit, Clevite main and rod bearings, 400 sbc balancer, chrome 1 wire alternator, .030 flat top pistons w/rings, aluminum polished finned oil pan, forged 5.7 bushed rods, ceramic coated headers, Quick fuels braided fuel kit, Quick fuels 4 barrel 600 cfm carb, 31x19 alumimum radiator, Eagle steel crank, HEI distributer, For the truck as it sits(unassembled), with every part and motor that I listed - $7200 Would also trade for family boat, open bow, runabout, or fish and ski. Will also, sell motor seperate and parts. If wanting a certain part I will post price including shipping. Would also like to sell motor parts as a complete unit. Pics that are attatched are of how truck looked when we got it. Just dont have time to finish, and we are wanting to do more family things at this time. I can send pics of everything if you want. Of how truck looks now, and all parts. Let me know if you have any questions. Title in hand. If anyone is interested in just truck parts, I will post a list and prices. This is not a completed truck. |
06-27-2012, 11:03 AM | #2 |
Re: 1967 SWB Project / Part out
How much for the bed?
DREW67 |
06-27-2012, 11:29 AM | #3 |
are you wanting tailgate also?
06-27-2012, 11:39 AM | #4 |
Also would like a price on the bed, with or without tailgate
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 |
06-27-2012, 01:18 PM | #5 |
DREW67 |
06-27-2012, 02:01 PM | #6 |
I'm interested inthe bed and all the five lug stuff
1965 c10 short stepside (dad's project) 1967 c10 fleetside 350/350 trans (my baby) |
06-27-2012, 02:18 PM | #7 |
Interested in tailgate pending pics
Posted via Mobile Device |
06-27-2012, 04:08 PM | #8 |
Please post prices OR list the truck in the trucks for sale section.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
06-27-2012, 04:58 PM | #9 |
06-27-2012, 05:15 PM | #10 |
In line on the bed also, don't need tailgate.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
06-27-2012, 05:16 PM | #11 |
Here are pics of bed.
$650 for bed only OBO $725 for bed and tailgate OBO |
06-27-2012, 05:29 PM | #12 |
Tailgate - $90 plus shipping if needed to ship
Does need a little bit of work, but in pretty good shape. |
06-27-2012, 06:52 PM | #13 |
Inline for the tailgate
06-27-2012, 06:57 PM | #14 |
how much for the doors and can you post some pictures of them?
06-27-2012, 07:18 PM | #15 |
Here is pic of doors. Includes glass, vent windows. the glass roles up and down pretty good. Doors in really good shape, passenger has a slight crease, but will pull out.
$475 for pair |
06-27-2012, 07:29 PM | #16 |
I dont have a pic of the 1-piece window kit. But here is the link to them. They are still in the box that I received them in. If you want a pic of the box let me know.
http://www.brotherstrucks.com/prodin...r=OPWK200%2DCL $425 shipped At this price will save you quite abit of money |
06-27-2012, 09:01 PM | #17 |
CPP transmission mount - $85 shipped
CPP motor mounts - $140 shipped CPP brake booster w/proportioning valve - $270 shipped |
06-27-2012, 09:12 PM | #18 |
Headers, ceramic coated w/ 3/8 flanges - $180 shipped
Chrome steering column 32" w/adapter, floor shift - $250 shpped CPP in bed chrome full fill and sending unit - $130 shipped Billet aluminum gauge insert(1/4" thick) and Shark gauges - $350 shipped |
06-27-2012, 09:17 PM | #19 | |
Some nice stuff you have for sale. Good luck with your sale, or sales.
06-27-2012, 09:27 PM | #20 |
member
Isn't this listed in the trucks for sale section? Aren't two listings for the same items against the board rules? What if you have parts pending and someone wants the whole truck package?
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide |
06-27-2012, 09:36 PM | #21 |
You are correct. I have it posted in completed trucks. I also have it posted on local forums also. This is the way that I see it. I will post what has sold and hasnt. I would like to sell it as a whole package, but if I can sell as a parted out truck, thats what I will have to do.
06-27-2012, 09:52 PM | #22 |
Hi, What sending units come with the gauges?
Also, do you have pics of seats and pics of chassis (and prices for both)
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 Last edited by 54belair; 06-27-2012 at 10:13 PM. |
06-28-2012, 06:07 AM | #23 | |
Will get pics of seats and chassis loaded tonight and prices. |
06-28-2012, 06:09 AM | #24 |
06-28-2012, 01:38 PM | #25 |
Yeah all, I'm wanting to do a 5 lug swap..... Pm me about the doors. Very very interested
Thread Tools | |
Display Modes | |
