Old 06-29-2012, 02:37 PM   #1
parrotheadmatt87
85 c10 seats in a 68?
Hello all!
My brother in law swapped a T56 in his 85 C10 and had to remove his old bench seat and had to install bucket seats. He left his seat with me and I was wondering if anyone has tried to fit them in their truck? Do you have to modify or is it a direct fit? I tried searching it but came up with no direct answer. Thanks for any insight!!
1968 GMC C1500 Short bed PO dropped in a 454BB/350T
parrotheadmatt87 is offline   Reply With Quote
Old 06-29-2012, 03:13 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: 85 c10 seats in a 68?
1. Remove your old seat.
2. Put the '85 seat in your cab. Line up any bolt holes that the frame of the seat will allow.
3. Drill a couple of holes (at the most) and use large fender washers beneath the floor, to then bolt the seat in place.
4. Adjust and drive.
Member Nr. 2770
Old 06-29-2012, 03:37 PM   #3
midniteblues
midniteblues's Avatar
We tryed this a while ago and it will not bolt in without drilling,even with it sitting in the cab the 85 seat felt very wrong
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 06-30-2012, 08:47 AM   #4
parrotheadmatt87
Did the cabin feel cramped?
Old 06-30-2012, 09:28 AM   #5
midniteblues
I'm sorry it was a long time ago that we tryed this, but iirc the seat was really low to the floor and i think shorter than the original the steering wheel felt like ape hangers and my son couldnt see over the dash.the 73-? trucks have a differnt floor pan.
If your really intrested try its only a couple of bolts maybe you will like it
Old 06-30-2012, 09:17 PM   #6
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I have an 80's seat in my truck that was there when I bought it. As far as fitment goes I'm 6' 2" and 230lbs with long legs and sit good on that seat. If you can wait a day or two I can take pics of it and how its bolted to the floor and post em on here for you. I am actually going to replace the seat with an original bench ( with black and white houndstooth) not because its uncomfortable but because I want the truck to look as original as possible.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 07-01-2012, 01:55 AM   #7
yunkyarddog
yunkyarddog's Avatar
found my seat (as you see it in the picture)at my local yunkyard its off an 84 c10 took it home took old one out... the back bolts lined right up, up front not so lucky well the seat frame hits my tranny cab hump and the bolt points are off the floor bout 1.5in nothing little square tubbing cant fix
Im stright up ESL student........ fixin my truck a trip to the yunkyard at the time
94 s10 4x4 4.3/5speed (dd)
68 lwb GMC 350/4speed
52 5 window GMC I6/4speed 12v (8lugs and long bed)
53 bel air 235 I6/powerglide
yunkyarddog is offline   Reply With Quote
Old 07-01-2012, 08:42 AM   #8
Did yo try putting the stock brackets on the later model seat? Since the 73-87 models have such an unlevel & elevated floor, it makes the later model brackets unusable.
You may try looking at an 88-94 model bench. They swapin with a minimum for fuse.
Old 07-01-2012, 10:51 AM   #9
kcsa75
kcsa75's Avatar
Swapping brackets worked for me. I have a bench seat out of a late model Ford F-150. I had to do a little measurin' and drill a couple of holes in the new seat, but it was no big deal and worked like a champ.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Thread Tools
Display Modes
