Old 05-17-2003, 09:43 PM   #1
72gmcshorty
72gmcshorty's Avatar
What causes electrical problems in the steering column?
I just traced my headlight problem to the steering column. Now I'm not sure what to look for and where. My left turn signal works but the right doesn't. Anyone have any ideas?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 05-17-2003, 09:48 PM   #2
68 Stepside
huh?
68 Stepside's Avatar
most likely the turn signal switch has crapped out.....can you wiggle the turn lever...and have the right signal come on?? How about the hazard switch?
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 05-17-2003, 09:49 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Have you checked to make sure that no wires are grounding out ???? And how did you trace the problem to the coloum....If you need any pic's I just tore my coloum apart.,.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-18-2003, 12:37 AM   #4
72gmcshorty
My hazard's come on steady, no blinking. When i put the turn signal on to the right it just stays lit steady. I haven't tried jiggling the turn signal thing though. I've traced the problem to the column because when it's plugged in, my front yellow lights and side blinker lights come on steady even when my headlight switch is not on.
1992 Gmc 2wd
Old 05-18-2003, 12:51 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Time to look for a van tilt to install.
Thread Tools
Display Modes
