Old 07-01-2012, 08:24 PM   #1
blackbear
Thumbs down 3/4 drop
for a 3/4 drop on a 65 long fleet would some of you guys recommend a 1 inch coil and 2 and a half drop spindle and a 4 inch coil in the rear.if so do i have to c notch or relocate my shocks. would i have any allinement issues.any info would help
blackbear is offline   Reply With Quote
Old 07-01-2012, 08:52 PM   #2
71swb4x4
71swb4x4's Avatar
Re: 3/4 drop
If they are old stock front springs, you probably won't notice any difference with 1" drop springs. Your old springs have 45-50 years of sag in them, they probably have at least an inch of drop with the sagging. Just do the spindles if you are OK with the old front springs. Doesn't hurt to change out 50 year old springs though. You won't have any alignment issues on the front, shocks will be fine too.
On the rear 4" you can get by without a C notch. If you will haul a lot you may want th enothc. Either that or do a 3" rear spring with 1" block, or 2" spring with 2" block. With 4" rear springs I would relocate the shocks and get an adjustable panhard bar.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-01-2012, 09:23 PM   #3
blackbear
Re: 3/4 drop
i forgot to mention i am putting in a bbc all steel and i have the stock 6 cyl springs.would they do with the drop spindles.
Old 07-02-2012, 09:47 PM   #4
71swb4x4
71swb4x4's Avatar
Re: 3/4 drop
I would probably get the new 1" drop springs if you are swapping to a big block.
You may see if a mod can tow this thread to the suspension forum. There are a lot of very knowledgable suspension gurus over there.
Thread Tools
Display Modes
