Pumps going, good time to replace column?
My power steering pump is leaking pretty bad so it's time for a new one, my question is would this be a good time to get a new steering column with tilt?
On a quite night you can hear a ford rust |
![]() Join Date: Jun 2009
Re: Pumps going, good time to replace column?
Is your steering box leaking or the pump? If it is just the pump it wont matter when you do it.
Posted via Mobile Device |
It's the pump, it's leaking being the pulley wheel. I was just curious if replacing the column would require draining all the fluid and all that and figured if I gotta do it already might as well do it all at once
The steering pump and power steering box have little to do with column, there is just s mechanical connection between the column and box. There is no reason to drain the fluid when changing the column.This is no better or worse time than any other to change the column.
Kwin |
Any body got pics of a column off and how it all works?
78K & 79C Jimmys
to fix the pump you don't need to remove it
this coupler joins it only to the steering box
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Hey motor nut where did u get that rag joint? Expensive?
Sweet thanks, I will just fix the pump then till I can find a nice column
#9 | |
78K & 79C Jimmys
I just put it on my account and they send it over Posted via Mobile Device
Thread Tools | |
Display Modes | |
