Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-09-2012, 08:02 PM   #1
El Campo
El Campo's Avatar
What is the truth about amperage vs CFM out of an electric fan?
I am still looking for the electric fans that I am planning on putting on the 72. Problem is that there is a zillion and one options with everyone saying theirs is the best. This is STRICTLY about electric fans, do not want to get started down the mechanical fan vs electric fan discussion again. The biggest question is this: Company A says that their 16 inch fan puts out 3600 CFM while only pulling 10 amps. Company B says that their 14 inch fan puts out 1500 CFM but pulls 18 amps. Does design alone of blades etc really make that huge of a difference that a fan will put out over double the CFM and yet pull nearly half less amps? And then (I am afraid to ask this question) what is the best fan blade design?
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 07-09-2012, 08:09 PM   #2
PGSigns
PGSigns's Avatar
Re: What is the truth about amperage vs CFM out of an electric fan?
What it all boils down to is the fan with the highest cfm and the lowest amperage is the most efficient design. So if two fans are rated at 2000 cfm and one pulls less power it has a more efficient blade and motor combination.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 07-09-2012, 09:46 PM   #3
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
an efficient blade may not be quiet...something to consider. I run a dual fan system that's on like a 30 amp, or 35 amp circuit?
my truck also has a modern alternator...I think 160amp?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-10-2012, 11:39 AM   #4
El Campo
El Campo's Avatar
I am wondering how realistic these CFM numbers are? I don't care if it is noisy, have 535 cubic inches running through 3 inch Flowmaster Super 44s anyhow.
Hook em Horns!!!
Old 07-10-2012, 12:07 PM   #5
Super73
Super73's Avatar
Jimmy
So you would hope...
I use to sell fans to server companies similar to Cisco. Obviously a bit smaller than car fans, but they had to move a lot of air, use as little power as possible and be able to stand up to ambient temps of 130* + for 24 hours straight. I have learned a thing or two
Originally Posted by El Campo View Post
I am wondering how realistic these CFM numbers are?Posted via Mobile Device
That is the real question. Or even better yet, how did they come up with their amperage draw? Companies fudge advertising all the time. The other thing to consider is actuall working amperage. Are the mfg's all rating their amperage the same way? What do I mean by this?
Is one mfg giving you amperage rating based on start up where the motor pulls the most current or continous working load where it is most efficient?
Next, what tempeture are they rating that current draw at? Some mfg's will test at a lower temp because there is less loss.
Also, what voltage was it tested at?
I will have to look at the fans on my Camaro. It's either a dual 10" or 12" and they were rated at over 2000cfm each. When on, they move a LOT of air. Don't know the amperage draw though.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 07-10-2012, 01:15 PM   #6
Marv D
Registered Truck Offender
Marv D's Avatar
Originally Posted by Super73 View Post
Companies fudge advertising all the time..
Oh come on ,, surely you jest!! You mean I can't depend on things getting longer, stronger, and have more stamina by simply sending in $50 for some FDC un-regulated little miracle pill?????
Oh NO I am so disappointed!!!!!
That's almost like saying some of the head manufacturers lie about flow numbers!!!
all that said,, BeCool makes a really decent puller fan, but they are sure proud of it.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 07-20-2012, 06:33 PM   #7
Boostedbowtie
I run fans out of a Town & Country van . Best fans I've ever had . Fits like a glove on my BeCool direct replacement radiator .
Boostedbowtie is offline   Reply With Quote
Old 07-22-2012, 08:11 AM   #8
djracer
djracer's Avatar
I would try a fan or pair of fans that Draw less current. I would make a nice aluminum or stainless shroud. The shroud and the design of the radiator are the key things. The next thing that only time will tell how long the fans will live. Make note of the brand you buy the first time and don't buy them again if they don't hold up. Do you already have the radiator for the truck?
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 07-22-2012, 10:58 AM   #9
El Campo
El Campo's Avatar
No I don't. Trying to buy one of those also. Was looking at the Griffin Extreme Cool which supports up to 800 HP with its 1.5 inch tubes. Is this necessary? Truck makes 600+.
Hook em Horns!!!
Old 07-22-2012, 01:44 PM   #10
Super73
Super73's Avatar
I am a big fan of OEM fans (no pun intended). 4th gen Fbody fans seem to never die and move a ton of air, as do the 3.8l ford taruas fans. If they fit in your chassis, not a bad idea.
Old 07-22-2012, 09:49 PM   #11
djracer
djracer's Avatar
These folks are the bomb dissle They custom made my two pass radiator. http://www.fsrproducts.com/
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-23-2012, 02:45 PM   #12
El Campo
El Campo's Avatar
djracer can you say how much that cost you? I went on their website and it was not user friendly and could not find a price anywhere or email. Does it cool the truck well?
Hook em Horns!!!
Old 07-23-2012, 08:06 PM   #13
djracer
djracer's Avatar
Mine was less than 300 to my door. Mine is pretty small and cools awesome. Mine doesn't have anything but two threaded bungs and a drain but the craftsmanship is the bomb.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-23-2012, 10:11 PM   #14
BigDan3131
BigDan3131's Avatar
I have Spal Fans, they work great and last a long long time.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 07-29-2012, 02:46 PM   #15
dwcsr
Hollister Road Co.
dwcsr's Avatar
There is a lot more to successful cooling than advertised CFM. There is no way you will get 3600 cfm on 10 amps pulling through a 4 core aluminum radiator. I suspect the 3600 cfm @ 10 amps is a free air number and not up against a 4 core or even a 2 core.
I to am a fan of OEM cooling fans. I prefer the Taurus or Mark VIII style fans either in 2 speed or single speed depending on what you want to accomplish.
The Mark VIII style 18' fans that includes Cougar and TBird 4.6 V8 fit the 72 stock radiator nicely giving you about 85% shroud coverage. 80% is the minimum to be useful.
I use one in my stock 72
http://www.thehollisterroadcompany.com/MarkVIII.html
http://www.thehollisterroadcompany.c...VIIIrelay.html
I also have a 460 BBC with 4 1500 cfm fans in a shroud that works very well but is loud as heck. http://www.thehollisterroadcompany.c...nShroud055.jpg
I use it on a stock 58 chevy 6 cylinder radiator to cool 550 hp. This may sound odd and against the aluminum radiator sellers bible verse but I didn't know any better and it works.
Some basics you need to know before you spend a ton of cash on fans a radiators.
1. if the air can't get out of the engine compartment it can't get in through the radiator. This is usually not an issue on a 72 unless the shroud and fan openings are to small.
2. 4 core radiator flow less air than 2 core. You need to determine if you have a need for 4 core or can use a 2 core. In some instances a 2 core can cool better than a 4 core. On the NastyZ site you can read how they use a 2 core with a high CFM OEM fan to cool better than a 4 core with a aftermarket 16' electric when they drop in LT1's and LSx motors.
3. A proper shroud needs to be designed in order to allow cooling at a stop and at highway speeds. A fully shrouded radiator with a 16' fan and a 600 HP motor will over heat at highway speed and may cool nicely at idle or low speeds.
4. Look at the back of the fan. If it looks like a spider web chances are it would not allow the full CFM out of the back. OEM fans are usually very open on the back side.
5. Pusher fans are usually a problem not a help.
6. There is no real correlation of x amp equals y cfm. There are to many variables that go into it to get an hard x = y number.
I'm sure some will disagree but these are my experiences with electric fans going back 12 -15 years.
dwcsr is offline   Reply With Quote
Thread Tools
Display Modes
