07-11-2012, 05:59 PM | #1 |
clutch fan installation thread?????
I did some searching on there and have not been able to find a thread on upgrading to a clutch fan.
Has anybody done such an upgrade, or know of a thread on doing this? Thanks!
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
07-12-2012, 07:52 AM | #2 |
Re: clutch fan installation thread?????
Stock engine?
Posted via Mobile Device |
07-12-2012, 08:17 AM | #3 |
Charlie Daniels w/ a Tq Wrench
I just did this on my 78 K30 a few weeks ago, I had to replace a leaking water pump anyway so I decided to swap to a clutch fan from the old direct drive while I was at it.
Look at rockauto.com, you will probably get the best prices there. I ordered the Hayden 3619 19" fan, they also make a 3618 18" fan, measure your existing fan/shroud to see what you need, and also a Hayden standard duty thermal fan clutch. Those are the only two pieces you need other than some shorter bolts to bolt the fan clutch to the water pump. I will forewarn you, the box the fan comes in "says" it is a flex fan...it is not, and Hayden confirms this, they simply use the same box for multiple fans. First thing I noticed, the fan is MUCH quieter. Cooling is just as good as it was before, I pulled a 5000lb boat around, with an additional 1000lbs ATV and gear in the bed last week in 106* heat and the needle never moved from it's normal running temp position with a 195* thermostat.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
09-01-2012, 12:12 PM | #4 |
Can i ask why you went with a thermal clutch? I am thinking to do the same and have read thermal is better then non thermal, expecially in hot climates with no cold winters. have the part number for the clutch?
" You are only coming threw in waves,... Your lips move, but i can't hear what your saying" |
09-03-2012, 08:33 AM | #5 |
I did this on a 65. GM makes different sizes fans so measure the shroud. I believe it should be the 18" fan. The fan is inter changeable with the clutch.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
09-03-2012, 10:46 AM | #6 | |
Yes, stock 283
Thanks for posting!
09-04-2012, 09:05 AM | #7 |
here are some for sale on here http://67-72chevytrucks.com/vboard/s...d.php?t=541408
09-21-2012, 08:22 PM | #8 |
I just installed on my 70 c 20, 350... a Flex a lite 18" clutch fan with a Hayden thermal clutch... Perfect fit, simple to install. Temp is the same, but that fan noise is gone!
09-22-2012, 09:35 AM | #9 | |
09-29-2012, 03:01 PM | #10 |
Does anyone know if it would be a different procedure for my 292? I don't have a shroud to worry about but I also don't have a whole lot of distance between the block and the radiator.
09-29-2012, 06:10 PM | #11 |
According to the summit website, the part numbers i used will fit the 292 from 1963 to 1971..
Part numbers i used were Hayden clutch 2705 flex a lite clutch fan 5718 Fan itself is a universal fit, just make sure of your diamiter. this fan is 18.250 **you dont mention a year, just recheck summit before ordering
09-29-2012, 08:22 PM | #12 |
I did it when dropping a new crate 350 in place of the original 283 in my '61 Suburban.
I found a factory fan shroud (!), measured the opening, and then went through the YearOne muscle car parts catalogs and found the biggest fan I could... I believe I ended up using a 7-blade fan for a big block Mopar with A/C. Then I got a Delco thermo clutch, and it all bolted right up to my Chevy water pump. I worked at YearOne at the time, and was able to take both GM and Mopar fans and compare them side-by-side, along with the clutch units: they were standardized bolt circles for bolting to the snout of the water pumps... Chevy fit Mopar, Mopar fit Chevy. I went with OEM-authorized parts... the aftermarket replacement had a sticker on the fan blades that said "Do not exceed 4,500rpm." I don't race my truck by any means, but I feel a whole lot more comfortable with a fan that was spec'd for an engine that was built to RPM, like a Hemi or a Corvette, rather than a fan telling me "It looks good, but the blades might come through the hood." As it is, I haven't gotten the fan shroud on yet... I have a wider/taller 3/4-ton 4-row radiator, and even with the fan set back about 8 inches from the radiator, at idle the fan moves enough air that it will hold a piece of paper tight to the radiator... it's moving some air. Just went over 51,000 miles with this combination, and drive it daily in Georgia (including summers) -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
09-30-2012, 02:57 PM | #13 |
Thanks so much for the info Brad, I am looking at a crate 350 as well, this is very helpful!
Thread Tools | |
Display Modes | |
